E-Class (W211) 2003-2009
Removing rear ac vents facelift
Old Feb 28, 2022 | 11:47 PM
gogydm's Avatar
08 E350
Hello,
I've searched the forum but cannot find an answer to my question. My rear vents on the 08 E350 (two zone AC) are broken and I need to take them off to replace them. There are bolts that need to be removed but I cannot remove the plastic that contains the rear storage compartment with the 12V power plug. I do see that there may be a bolt in the back that holds it in but I cannot get to it. I see that on the older design armrest you could access the bolt but I can't figure it out on the facelifted versions. Right now there is a MHI connector and the lining does not seem like it can be easily removed. Does anyone have experience with this?
Thank you!
Old Mar 1, 2022 | 09:48 AM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 2, 2022 | 01:25 AM
gogydm's Avatar
08 E350
Thank you @konigstiger , useful with WIS as always. That's what I feared will need to be done.
