Brakes need replacing
When I had my car serviced a few weeks ago, mechanic advised me that the brakes were nearly worn out.
My q is this - will I get a message due to the wear sensors to replace the pads/discs? Can I wait until I get the message? Or should I replace the pads and discs ASAP?
I've decided to get the brakes done next Friday.
Absolute minimum remaining friction material on any one pad is 4mm (0.156”). A good visual guide is when the pad surface is worn down to the thickness of the backing plate, it’s time to replace.
You are never wasting money keeping the brakes in top condition.
stupid for mercedes to eliminate the left side sensor, the problem is if you are on vacation and it happens and mechanics are backed up in work, or they won’t deal with a mercedes or...sure if you live in germany its probably not a problem.
They were semi metallic pads, not sure why the left wore down 30% faster, but since then I only use ceramic pads.
Luck beats skill,
Peter
If one was to switch to aftermarket ceramic pad / G3000 rotor kits available online, would I avoid this need to replace both parts (assuming its required)?
I’ve been replacing rotors on every second pad change with semi-metallic pads. On my one car with ceramic pads, the rotor is worn below minimum spec by the time the pads are worn. But the ceramic pads last three times as long, so it’s okay.
I don’t have experience with the aftermarket parts because I’ve stuck with MB pads and rotors.
My E280 has 2 sensors -1 front right and 1 rear right. So yes, if the left side wears quicker, you may be metal-to-metal before the sensors trigger.
