E-Class (W211) 2003-2009
Checking the oil level in the cluster.
Old Mar 8, 2022 | 04:00 AM
brains646's Avatar
07 E350 Sport m
Is this functionality optional? My manual says I have it but I can’t seem to make it work. Same for tire pressure monitoring. I don’t have the valve stems but my question is, was it standard? If I replaced the stems would it work?
Old Mar 8, 2022 | 10:22 AM
konigstiger's Avatar
'71 Pinto
If I remember correctly 07 switched to dipstick dash menu was eliminated.
Old Mar 8, 2022 | 11:52 AM
brains646's Avatar
07 E350 Sport m
That would make sense. Thanks
Old Mar 8, 2022 | 12:28 PM
rbm's Avatar
rbm
2008 E300 4MATIC
I have an 08 E300 and it is not possible to check oil level from the dash.
Runflat option 477 may be available; check your VIN and see which options were included with your vehicle. TPMS won't work if you just install the senders in the stem valves on the rims. You need proper cabling and control unit in the car as well as having the car programmed to recognise it. Not a trivial task I understand.
Old Mar 9, 2022 | 04:47 AM
brains646's Avatar
07 E350 Sport m
thanks for the info. I’m not interested in adding it as much as I wanted to make sure something wasn’t malfunctioning.
Old Mar 12, 2022 | 01:11 PM
ptkacik's Avatar
2005 E320 CDI, 2015 GLA 250
My ‘05 CDI does not have a dip stick. How do I measure it?
Old Mar 12, 2022 | 10:08 PM
F1Fan's Avatar
This might help.
