E-Class (W211) 2003-2009
W211 quantity control valve y94 problem
Old Apr 5, 2022 | 05:40 AM
gogetit's Avatar
w163
Hello,
I have a problem with my w211 220 CDI Mercedes.
After the start of the engine y74 valve on the rail controls the fuel and a few seconds after engine starts the control is moved to y94. After the control is moved to y94, rail pressure go high and engire starts working roughly. I tried to change the y94 valve, but without effect.
The ECU wont controls y94 fuel quantity valve. The ECU sends permanent square signal to it and wont change it. The y74 rail pressure valve is controlled normaly, the ECU changes duty cycle of the signal.
Old Apr 5, 2022 | 08:25 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
look like your coolant temp is too low... that may help ECU decide to enrich mixture with higher fuel pressure.
Old Apr 6, 2022 | 04:21 AM
gogetit's Avatar
w163
There is no change, when the car goes to working temperature.
Old Apr 6, 2022 | 12:24 PM
volume valve vs. pressure valve
the rail pressure at 519Bar (7500Psi) gets up way higher than 340Bar Max (5000Psi) !
What regulates the pressure may be leaking right through, really odd.
Old Apr 22, 2022 | 03:04 AM
gogetit's Avatar
w163
I tried to changed quantity valve and rail pressure valve with new ones. After that I changed injectors, input calibration data to the ECU, but still got a high pressure. I bought a second hand ECU and not change with it, still high pressure .
Old Apr 22, 2022 | 03:28 PM
"Too much pressure" enigma
Recap: you've replaced both quantity valve and pressure valve and pressure still remains abnormally way too high. ECU + Injectors also replaced. All without significant improvement.
You have observed the ECU not changing control of Quantity valve but normally ramping command of Pressure valve... That control does sound normally working.
> How is the pressure measured and regulated..?
> Can you observe the live pressure value change between engine off vs. running?
>Is there a filter problem on low-pressure pump side ? (Could this be the ECU trying to compensate for low pressure feed)
It'll interesting to get this pressure control enigma figured out.
Old Apr 25, 2022 | 02:37 AM
gogetit's Avatar
w163
The pressure is measured by pressure sensor on the rail, which seems working normally, because 10 or 15 second after the engine starts pressure is regulated by rail pressure sensor and the pressure is in the required range.
I think that if there is filter problem, the engine will starts hard.
Old Sep 19, 2022 | 03:46 PM
kepa75's Avatar
w461
Hello,
I'm new here, writing from Northern Italy.
Just wondering if this problem got solved? I've also a problem with high rail pressure (and a noise) and I'm to find solutions.
Thanks,
Peter
Old Nov 15, 2022 | 01:16 PM
3lencio's Avatar
W211
Any update on the issue? Having same problem ,
Originally Posted by kepa75
Hello,
Thanks,
Peter
Just changed the quantity valve y94 no luck . Engine light on after hitting 3k rpm and cracking noise from engine . Any update ?
Old Nov 19, 2022 | 04:01 AM
kepa75's Avatar
w461
Hello, in may case all the injection system (high pressure pump and injectors) has been controlled and seems ok.
My mechanic thinks that the noise comes from the chain.
Ciao,
Peter
Old Nov 19, 2022 | 08:25 AM
3lencio's Avatar
W211
Ciao,
Peter
Hello just an recenly update. i cleaned the EGR . Now i dont get high pressure anymore. But the strange thing is that from High went to Low pressure comon rail. I dont think that the noise comes from chain , Because no Engine light no noise . ENGINE LIGHT ON( noise comes)
Old Nov 29, 2022 | 06:08 AM
3lencio's Avatar
W211
UPDATE. (COMRAIL PRESSURE SOLVED) in my case the injector failed the back lesk test. I ended up rebuilding all 4 injectiors. 220 euro each . Changed even electric cable of injectors . Total cost 1000 euro.
Old Dec 21, 2025 | 10:37 AM
KaloKK's Avatar
w204 om646 170hp
Hello there
Im searching about a high pressure regulator 22E7 and as I look the previous reply's it seems the problem look like mines.
Im not getting a fault in Y94 and Y74 and I also have no idea about the status of the injectors,but the question about you'r solution might help me.
Do you went as far as changing those 2 components,before checking the injectors,( Y94 & Y74 ) and do you also get the same fault as mine - Test Of high-pressure Regulation : fault code 22E7 ?
