E-Class (W211) 2003-2009
Tele aid visit workshop
Old Apr 6, 2022 | 11:46 PM
Johnnyb46's Avatar
2007 cls 550
My radio will not cut on all I get is the logo and back to a blank screen but it only happens when I get the SOS Tele Aid Visit workshop on the dash can someone point me into the right d
irection
Old Apr 10, 2022 | 03:02 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
This message is the result of the old analog radio frequency based Mercedes SOS driver emergency system in the vehicle looking for a radio signal, but there is none because Mercedes no longer transmits or receives these. It's similar to GM's "OnStar" Newer MB's have a different digital radio system activated for SOS signals.
MB dealer service, an independent service center or someone with a cloned China MB programmer can shut it off for you with a few keystrokes so keep that in mind when you ask for pricing. Should take way less than an hour, but most mechanics have an hour minimum fee. MB might charge you for a flat rate hour minimum diagnostic fee then another hour minimum to de-program the SOS.
Old Apr 10, 2022 | 03:05 PM
Johnnyb46's Avatar
2007 cls 550
Thanks I took it to the dealership they said I need a audio gateway module and it will cost me $1100 to fix
Old Apr 10, 2022 | 03:57 PM
konigstiger's Avatar
'71 Pinto
04 e550 4matic - check splitter for corrosion, check module connections located in front center trunk panel. All fine, have someone with MB diagnostics code Teleaid from ‘present’ to ‘not present’: Control Units - Body - CGW (Central Gateway) - Control Unit Adaptations - Read Coding and Change if Necessary - Telecommunications - Telematics Service “TeleAid” in combination with MOST technology…
Did dealer document fault codes on invoice confirming AGW is bad? If so, I believe replacement part # is 2118706989 you can shop used need VIN to confirm. Usually plug & play but any problems after install may need coding (see line 1 AGW attachment).
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 10, 2022 | 04:02 PM
Johnnyb46's Avatar
2007 cls 550
No they did not tell me nothing bout no codes they just said change the module but when I first bought the car it wasn’t working then one day i came to get in the car the radio was working now it stoped working again but I check the trunk everything seems fine and intact no corrosion or split wires
Old Apr 13, 2022 | 12:08 PM
ptkacik's Avatar
2005 E320 CDI, 2015 GLA 250
Yes. My error message was caused by corrosion in the little connector from the rear GPS antenna. It is located in the trunk and water would leak in, run down the wire and get in the connector, corroding it. The connector is on a matchbox sized antenna splitter glued to the fender next to the left trunk arm. The connector unclips weird and I almost broke mine assuming it unclipped opposite the way it looked.
I cleaned up the connection and filled the plug with bulb grease to keep out water. I also attached a piece of tape to divert any water still running down the wire to drip away.
After three years, it came back. I opened it up cleaned it out again, greased it up, and it has been good for two more years.
Good luck with yours,
Peter
Old Apr 21, 2022 | 03:16 PM
Johnnyb46's Avatar
2007 cls 550
Peter
Old Apr 21, 2022 | 04:09 PM
ptkacik's Avatar
Yes. That's it.
Two wires out the bottom and one in the top. I think the red and black connectors release by squeezing at their tips rather than half way back. Or maybe the other way around.
Anyway, water trickled down from above and corroded the connectors. I cleaned mine as well as I could and filled them with "bulbgrease" like you get in a little packet at the checkout counter at a Pep Boys or O'Rileys.
Peter
Old May 10, 2022 | 10:05 PM
Johnnyb46's Avatar
2007 cls 550
Hey
Guess what the dealership tried to charge me $1100 to fix my tele Aide problem I said no I fixed it myself they so called said they look and it was bad due to water damage in the trunk but they lie it was the fuse number 5 in the trunk next to the battery they almost pulled one on me glad I looked one more time before giving up
