E-Class (W211) 2003-2009
What's the damage?
Old Apr 18, 2022 | 10:52 AM
W211Guy's Avatar
W211
What's the damage?
Hit a curb, why is the 4matic cradle so low...
Old Apr 18, 2022 | 11:58 AM
Heguli's Avatar
2006 E280
Looks like the sway bar bracket took the impact.
Old Apr 21, 2022 | 10:48 AM
W211Guy's Avatar
W211
Any idea what this might cost? I looked up parts and only the bracket base (back) can be purchased, the actual bracket (front) seems to come only with a brand new sway bar. Also it looks like the part of the subframe where the sway bar is attached is bent, I hope this can be repaired and not require a whole new subframe. Does anyone have experience with this kind of repair?
Old Apr 22, 2022 | 12:50 PM
Heguli's Avatar
2006 E280
I'd look for someone parting out their car, or wrecking yards.
As for the bent part, hard to say without seeing it, but moderate heat and a slide hammer might do the trick.
Old Apr 23, 2022 | 10:47 AM
Overheated's Avatar
1998 E320 Wagon, 2003 W211 E500, 2003 W211 E500, 1999 W210 E55 AMG
New sway bar, bushings and brackets, possibly find hardware here: https://www.lkqpickyourpart.com/
Put it back together then visit a collision shop for an alignment, if possible.
Old Apr 23, 2022 | 02:30 PM
Heguli's Avatar
2006 E280
Yeah, definitely an alignment after such a hard impact.
Old Apr 23, 2022 | 05:03 PM
tjts1's Avatar
C320
I see a cracked front subframe tucked up behind the sway bar.
Ouch!
Old Apr 23, 2022 | 06:52 PM
cetialpha5's Avatar
The subframe you can find on eBay or at a junkyard. I think it's about $300-$400 and over $1000 at a dealer. I actually had to replace the plate on the subframe connecting the steering rack to the subframe but it didn't come separately, the old one rusted out. Got it at a pick and pull but the lowest price I got quoted at a local junkyard was about $200 for the subframe. As others said, you might just be able to bend the subframe back, probably a lot in labor to replace the subframe. The sway bar basically comes as one assembly as the bushings are glued on so you can't just replace the bushings. If you hit something maybe you can claim it on your insurance.
Called all the local junkyards on this list. Several of them said they'd look and call me back. None of them did.
https://www.car-part.com/
