E-Class (W211) 2003-2009
Smoke coming from engine bay e320
Old Apr 23, 2022 | 04:21 AM
4dan7's Avatar
2007 E320 BlueTec
Hi all, recently my 2007 E320 Bluetec has had pale white smoke coming from the front (left) drivers side of the engine bay. Followed with a slight burned diesel smell. This lasts for about 3-5 minutes and so far this has happened 3 times and all while idling in traffic weirdly enough.
There are no warning or engine lights on the dash either and the temperature reading slowing builds but does not exceed 70-80 degrees celsius and there is no light.
Each time I have popped the hood and looked for any signs of burning I see none. My oil, coolant, window washer and transmission fluid are all at a normal level.
Any insight on what this problem could be is greatly appreciated. Thanks.
Old Apr 23, 2022 | 10:02 AM
tjts1's Avatar
C320
Your engine has black death. One of your injector seals is leaking.
Old Apr 23, 2022 | 10:18 AM
F1Fan's Avatar
Good luck with that!
Old Apr 23, 2022 | 11:40 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
If it is black death, dealing with it sooner than later will be cheaper. Remove the engine covers and have a close look at each injector hole in the valve cover.
Old Apr 24, 2022 | 06:49 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
FWIW.... You may want to open your messaging for future notices from other members.
R,
2Merks
