E-Class (W211) 2003-2009
More understandable wiring diagram for W211 (211.241)
Old Jul 1, 2022 | 11:06 AM
boomer56's Avatar
E200 Kompressor 1.8 L W211 Petrol Finland
Question More understandable wiring diagram for W211 (211.241)
Could somebody share component level wiring diagram for MB e-series w211? Year model 2006 1.8 L automatic, gasoline.
More simplified wiring diagram needed.
I've got two wiring diagrams, but don't have a clue how to read them.
I've got "Wiring diagram for ME-SFI[ME] gasoline injection and ignition system
control unit /pe-07.61-p2101-99dd ENGINE 271 as of 1.9.02 in MODEL 211
Steuergerät N3/10. Blatt 2' / Printed on: 03.02.2017" (four pages + two pages
with index.
Also having "Wiring diagram for ME-SFI [ME] gasoline injection and ignition system
control unit / pe07.61-p-2101-99dc ENGINE 271 as of 1.9.02 MODEL 211
Steuergeät N3/10, Blatt 1' / Printed 04.02.2017" (four pages).
Last edited by boomer56; Jul 1, 2022 at 11:35 AM. Reason: Adding two wiring diagrams
Old Jul 1, 2022 | 04:34 PM
Heguli's Avatar
2006 E280
Can't be any simpler diagram than those that you provided! What's the issue you're having with them?
Old Jul 1, 2022 | 06:50 PM
boomer56's Avatar
Red face
Thank you for your response. I just need to learn more about these drawings.
I don't know if there are any Haynes books out there, for example.
For example I'm after crankshaft sensor L5. What these abbreviations EF a and EF B mean?
I understand that those are somewhere in N3/10 (ECU or ECM).
Lets take another example. Left intake camshaft Hall sensor B6/4 have wire 0,5 BNGN (brown/green) going to sensor ground connector sleeve called Z6/8z1.
Maybe I'm blind or so tired. Time is 1:30 A.M here. I haven't found it.
Wire 1,0 BNGN (brown/green) is continuing to N3/10 to point (pin) 53. There is also number 31 inside N3/10. Where is this number 31 pointing? Is it internal number again?
Is there somewhere out data/glossary about these AP ULK+, EA IP2S, EA ULK1 and so on.
Sorry about my bad writing.
Something I understand though.
Sincerely
boomer56
Old Jul 3, 2022 | 02:50 PM
boomer56's Avatar
Fault in engine
Found damage. Drive chain damaged and teeths nearly gone from camshaft parts.
Old Jul 4, 2022 | 05:52 AM
rbm's Avatar
rbm
2008 E300 4MATIC
This is a DIN standard 72 552 designation for return to battery. There are other DIN designations in that diagram like 87, 61, etc. A Wikipedia reference for DIN standard 72 552 is here: https://en.wikipedia.org/wiki/DIN_72552
Old Jul 4, 2022 | 06:02 AM
boomer56's Avatar
Many thanks for answer.
Regards
boomer56
