E-Class (W211) 2003-2009
2020 W213 Rim A2134011400 on 2008 W211?
Old Sep 4, 2022 | 10:28 PM
SYNDK8's Avatar
2008 E300 4MATIC
Question 1
Would this fit my 2008 E300 4MATIC?
Question 2
Stock size is 245/45/17 for the 4MATIC, would 245/45/18 be ok? as I was checking fitting charts and for w211 it is recommended 18x8 - 245/40/18
https://www.alloywheelsdirect.net/in.../mercedes-benz
Rim size: 8Jx18 ET 43
Part Number: A2134011400
Bolt circle: 5x112
Pirelli Winter Sottozero 3 245/45R18
Rim size: 8Jx18 ET 43 Part Number: A2134011400 Bolt circle: 5x112
Old Sep 5, 2022 | 09:26 AM
SYNDK8's Avatar
2008 E300 4MATIC
If I am reading the below site right, these rims should fit right?
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Old Sep 5, 2022 | 10:52 AM
SYNDK8's Avatar
2008 E300 4MATIC
The yellow is my car, the white line is for a bolt that corresponds to the above rim from 2020 E350, would this be an issue for my car or is it just showing the size of the bolt required for 2020.
Old Sep 6, 2022 | 11:08 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
It is not only about tire size, but also offset and bolts. Since your car is 4matic, you want to be as close as possible to specifications. This topic has been discussed for several models in the forum.
For the offset, the number highlighted is the one for those wheels
Old Sep 6, 2022 | 11:13 AM
SYNDK8's Avatar
2008 E300 4MATIC
I went to see the rims last night and i definitely need the longer bolts from the 2020.
In the top link i compared the two ET. thank you for the 4matic reminder, I will pass on these rims then.
6 Father's Day Gift Ideas Your AMG Loving Dad Will Cherish
Slideshow: Six Father's Day gift ideas your AMG loving dad will cherish.
By | 2026-06-03 16:34:48
