E-Class (W211) 2003-2009
Arnott rear air spring 5380 code
Old Nov 28, 2022 | 11:00 AM
DuhStig's Avatar
E320 CDI
So today I replaced both my rear air Matic Springs on my 2004 E320 cdi wagon . I had no codes whatsoever on the factory Mercedes air springs setup . I just changed them due to the mileage on a vehicle with the Arnott 2724. But now I’m now getting an error code 5380 . This is odd I had no codes before
Thoughts?
Old Nov 28, 2022 | 07:31 PM
tyabnet's Avatar
2000 C230 - 2001 E430 - 2003 E320 -
Check the electrical connection on top left air mount, make sure the pins/plug are ok and clean and the plug is tight. Make sure to hit both male/female with electrical cleaner and let it dry. If the plug needs to be replaced, it is electrical part A 008 545 63 26 - that is a common connector and should be available at any MB dealer (or online in many places).
Old Nov 29, 2022 | 05:33 AM
dvenneman's Avatar
E350 4matic Wagon
Relays
Thoughts?ftore ore . I’m a mechanic by trade from USA . Any help would be appreciated ,
I believe that Mercedes replaces relays at the same time.
Old Nov 29, 2022 | 01:27 PM
DuhStig's Avatar
E320 CDI
So an update. Plugged in my old mb air struts . Code went away . Defective Arnott air spring . Called them directly here in Europe . They already have one being shipped from the Netherlands to Austria . Sucks this happened , but good customer service 👍🏼
Old Dec 1, 2022 | 09:27 PM
rodneypierce's Avatar
2009 e550 4Matic
I've got a similar code (open circuit code) and have since shortly after installed. Doesn't hurt anything, just gives the annoying error on the dash. Not worth taking the time to change the bag, when that part of the bag is non existent anyways (they don't use the extra volume)
Old Dec 1, 2022 | 09:54 PM
DuhStig's Avatar
E320 CDI
yeah unfortunately my car rides like crap with this code and the active suspension intermittently works . So I need the new part :/
TFTI. 👍🏼
Old Dec 1, 2022 | 11:08 PM
2009 e550 4Matic
TFTI. 👍🏼
ah. I know some codes will set the suspension to full stiff. And in that case, yeah they ride like total crap. Mine is lowered so it doesnt ride all that great anyways. haha.
Old Dec 2, 2022 | 07:50 AM
DuhStig's Avatar
E320 CDI
So … no code now after I installed the new air spring . But…… the left rear side sits a little lower then the right . Also the active suspension buttons don’t work after I chose to raise the suspension . It randomly turns on and off .
other then that the car rides fine but on my car soft scanner shows the rear level sensor -21mm
Thoughts ?
Old Dec 3, 2022 | 08:37 AM
DuhStig's Avatar
E320 CDI
So this morning went to the car like magic everything works . Drove about 120 miles on the autobahn . Everything works 🙌🏼 knock on wood . Thanks for the input guys . I’ll post again an update in a week or so . Have a great day . Going to watch USA VS NETHERLANDS play
