E-Class (W211) 2003-2009
Correct terminology for front "crossmember"?
Old Jan 30, 2023 | 11:49 AM
RA030523's Avatar
E320 CDI
I'd always just called them K-members. I'm trying to locate torque specs in WIS and the best wording/terminology that I can find is "engine support." Is this the same thing? I mean, suspension pieces also bolt up to it, so "engine support" seems a pretty limiting terminology for this piece. There's also a section "Axle/engine sub-frame," which I'd think would be the right terminology, but it has zero references to the front- it's seemingly all about trailer stuff.
Old Jan 30, 2023 | 12:07 PM
konigstiger's Avatar
'71 Pinto
Try searching subframe, in EPC it's under 62 cowl,front panel - 030 wheelhouse,front subframe -300
Old Jan 30, 2023 | 02:01 PM
RA030523's Avatar
E320 CDI
Found what I was after in WIS, section 33 "Front axle". What I'm interested in they refer to as the "front axle carrier". Well, OK...
Old Jan 30, 2023 | 02:40 PM
'71 Pinto
Forgot to attach capture to my last post.
Old Jan 31, 2023 | 04:28 PM
RA030523's Avatar
E320 CDI
Yes, that's it. (picture is worth a 1,000 words)
