E-Class (W211) 2003-2009
Windshield washer fluid leaking
Old Mar 12, 2023 | 07:18 PM
frizzo000's Avatar
E350
Hello all, I have a 2007 E350 which has developed a windshield washer fluid leak at the sprayer housing. Does anyone know if I have to replace the nozzles or is it possible to clean them. I attached pics of where it's leaking. The connection from the hose to the nozzle body clicks in but fluid is gushing out of both when I turn on the nozzles. I don't want to spend money on the parts unless there's no other solution. Thanks for your time.
this seems to click into the nozzle body but fluid is fushing out heavily. Not sure if its because the nozzle is clogged. This it the nozzle closest to the reservoir and it has the t connector where fluid continues to the driver side nozzle/sprayer.
Old Mar 13, 2023 | 12:09 PM
konigstiger's Avatar
'71 Pinto
You can clean out nozzle jet holes by using makeshift metal pick being careful it is compatible with exit holes as not to damage. Here is the part # if replacement is needed, see attachments.
File Type: pdf
