E-Class (W211) 2003-2009
Fuse 13 keeps blowing (Rear Cigarette socket)
Old Mar 16, 2023 | 07:37 PM
efonz's Avatar
2005 E500 AMG Appearance Pkg
Does anyone know what else fuse 13 controls, is it only the cigarette socket in the backseat?
I replaced the blown 15A fuse and it keeps blowing, not sure what to do next...
Old Mar 17, 2023 | 12:45 AM
konigstiger's Avatar
'71 Pinto
Check socket.
File Type: pdf
Old Mar 18, 2023 | 11:59 AM
efonz's Avatar
thanks konigstiger, device in question was a 12v air compressor I use for my tires. I plugged it in to each of the 12v sockets thinking they were all governed by the same fusE, this is not the case as each socket has its own fuse. the compressor blew each of the sockets respective fuse; compressor is at fault. I cut the 12v plug off the end of the power cord and spliced the cables to a 10A AC/DC transformer (brick) and plugged it into a wall outlet (works now). The only drawback is that it is no longer portable.
Old Mar 19, 2023 | 11:58 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
large load connection
PLAN B:
Splice in alligator clamps to connect compressor directly on battery jump points.
Old Mar 22, 2023 | 04:09 AM
efonz's Avatar
PLAN B:
where are the battery jump points? or do you mean the actual battery posts on the battery itself?
Old Mar 22, 2023 | 04:38 AM
bishop64's Avatar
2021 S450 4Matic
Battery is usually located in the trunk and can be cumbersome to reach. There are jumping points in the hood area where you can access more easily.
https://mbworld.org/how-tos/a/merced...battery-388061
