2009 E550 4Matic P0300
I want to knw do I have a bad or leaking head gasket problem I changed spark plugs coil packs and my car is still showing signs of miss fire but only on the bank 1 side cylinder 134 keep showing songs of misfire doing start ups car checks engine light flashes a couple times then stops and cars idles fine I’ll clear the codes it won’t come back but when u drive it it’s good no power lose or anything just that lil tiny shake in the engine every now and then from missing but no check engine light what can it be is my engine bout to go or the head gasket bout to go on that side I’m lose
Received 1,546 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
May I ask where the idea of a bad head gasket is coming from? Is the engine overheating? is there oil mixed with coolant on either reservoir? Are you adding missing coolant w/o any sign of leakage anywhere (burning coolant)?
Perhaps you are referring to an intake gasket between the intake manifold and the engine block. They are very different issues and very different prices when repairing.
Misfire can be caused by many things since it means the combustion is not proceeding as expected, so it can include:
1 - Bad spark plugs (worn/broken)
2 - Bad ignition coil packs (worn/shorted/cracked)
3 - Bad wiring from ECU->Ignition coil packs (damage wiring, oil in the harness)
4 - Bad injectors (worn, dirty, clogged)
5 - Bad wiring from ECU->Injectors
6 - Air leak in the intake (intake gasket)
7 - Bad fuel pressure (fuel pump damaged, clogged, etc)
8 - Bad valves (burned, carbon build up, etc) --> Lack of compression
9 - Oil in the combustion (worn engine) --> Lack of compression
10 - Coolant in the combustion (head gasket)
There is plenty of issues before getting to the worst ones at the bottom. There are steps to isolate each of them before changing parts. But a blown head gasket will have more than just a misfire.
AllPhonesAretap (03-27-2023)
P0300 is a generic misfire code. P030x where x is the cylinder number is the specific cylinder misfire code.
ok I came from the shop and he checked my spark plugs they are black he says my passenger side is getting to much gas on that side I’m thinking my piston are going as or the walls or it might had jumped time
Received 4,430 Likes
'71 Pinto
How about this...
The following 2 users liked this post by konigstiger:
AllPhonesAretap (03-27-2023),
juanmor40 (03-23-2023)
The keyword with these engines is diagnostic, diagnostics, and one more time diagnostic. If you have the money to throw parts at it w/o a diagnostic, I have a bridge for sale
The MB diagnostic tool can even measure the stretch of the timing chain, and tell you if you are off-timing w/o removing a single bolt.
'71 Pinto
Of course codes but think of what simple smoke test might quickly reveal.
Thank you for posting Dan's video. I had forgotten about it.
I made a appointment to drop the car off to the dealership this Thursday coming up hopefully they can find the problem and I’ll keep you guys updated
