E-Class (W211) 2003-2009
2005 E500 Wagon "Airmatic Visit Workshop" warning help
Old May 20, 2023 | 03:11 PM
123456789jimmy's Avatar
2005 E500 Wagon
Hi guys, got this airmatic warning sign and needed some help.
Ride mode switching is working (Comfort, Sport1, Sport2)
Vehicle rise is working, all 4 corners are rising and lowering, (took a measurement and all 4 corners rise about 1/2 inch, is that the correct amount?)
I only have an obd scanner and it is not giving any error code, I do not have a diagnostic tool at the moment.
Anything I can do to troubleshoot? Help will be appreciated!
Old May 20, 2023 | 08:04 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Gud day,
Recommend getting on all fours and checking the rear bags. Check condition to see if any "holes, rips, or tears are present. For front spray boitle soapy h2o and spray around the airshocks and "rubber portion", your verifying blubbles which will tell you you have a leak, also the pump itself. Also view interweb, and this forum for more content pretening to airmatic shocks. Plenty of info and valuable information. Not to rain on your parade, but if you find you have an issue with either its best to swap out in pairs vs. just doing one. Just my opinion. Gud luck
R,
2Merks
