E-Class (W211) 2003-2009
Wagon Suspension
Old May 30, 2023 | 03:52 PM
lyonsfin's Avatar
2009 E350 4matic wagon, 1980 450SL, 2011 GL450
Wagon Suspension
I have owned a 2009 E350 4matic wagon for about 4 years. Purchased with 130k miles now 157k miles. The rear end has always sunken down evenly after a week or so and now sometimes drops overnight. Always evenly and always back up with 1.5 minutes (or less). Are the bags leaking, a hose leaking or a valve? Replace everything or convert to coil springs?
Old May 30, 2023 | 04:02 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Have you scanned the car for any codes?
I would approach the issue with a budget in mind. Check for leaks:
1 - If it is a hose or a valve , just fix or replace. Done
2 - If it is an airbag, then you need to work out the total replacement cost: "how many bags + labor + unknown parts when replacing" vs "coil conversion plus unknowns"
It is always best to check for leaks and find the root cause, estimate cost and weight future costs vs convenience. You gain something with coil springs as well as you loose something --> your call
Old May 30, 2023 | 04:24 PM
E55Greasemonkey's Avatar
This place is a joke.
Put some Arnott bags in the rear. Avoid the cheap ebay/Amazon ones.
Old May 30, 2023 | 04:34 PM
tjts1's Avatar
C320
Whatever you do don't buy Arnotts. There have been so many complaints.
Old May 30, 2023 | 04:37 PM
Had them on my E55 for 3 years now, no problems and the back won't drop for weeks.
Old May 30, 2023 | 07:11 PM
rodneypierce's Avatar
2009 e550 4Matic
I've also got them in the rear of my e550. They don't leak, and they work great. As long as you don't need the adjustable suspension, as mine has had a bad resistor since nearly new.
Old Jun 22, 2023 | 03:42 PM
Onyxthecat's Avatar
06 E500 4Matic Wagon
Unrelated to the airbag system, I had the Arnott coil over set for my wagon and the rear springs sagged 3". The fronts were fine but I could not get the car to be level. The "Engineering" team attempted to help resolve the problem but then ghosted me after I sent pics of the issue. Arnott makes decent airbag replacements but, DO NOT buy the coil kit. BC Racing FTW.
Old Jun 22, 2023 | 07:26 PM
tjts1's Avatar
C320
Read the w220 forum. Arnott's airbag suspension engineering is just as problematic.
Do not buy Arnott.
