Trans fluid leak
Any insight would me much appreciated.
2006 E500 4Matic Wagon
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
I should have looked closer before I cleaned it up, but the pictures seems to show red fluid on those sensors.
Thats probably what it is though I'd just fix that and come back. Brakleen everything clean and come back to it after you've replaced your drain plug washer
I also don't believe the drain plug washer is copper. I'll know for sure when I drain the oil.
Remove the black rectangular covers on the bottom of your transmission housing. Look and see if you see oil at the rear main seal plate.
Use UV dye to easily identitfy where it's coming from.
https://youtube.com/shorts/U02Vti7zdQQ?feature=share
https://youtube.com/shorts/PYU8mb-6qpQ?feature=share
Where are you located? I'm in Oregon and will be doing my rear main seal soon. Maybe I can help you out with yours too.
And I've pretty much ruled out it being ATF. Even so, I picked up a trans fluid dipstick and will be checking the level soon.
I appreciate all the input so far.
Btw, if you haven't exchanged the trans fluid before, the 722.6 loves fresh clean fluid.
