Has anyone that got the SBC brake recall gotten the software upgrade done yet
They also updated/flahed the central gateway software too. (Also transparent)
The recall doesn't fix anything because there is nothing broken. All it does is change a program to count the number of times you activate the brakes. This stems from problems some very high mileage cars in Europe had with bubbles in the fluid reservoir. This only happened on vehicles such as taxis which had hundreds of thousands of brake applications. You will not live long enough to apply your brakes 300,000 times.
In any case, I have no intention of wasting the better part of a day having this change applied. They can do it when and if I take the car to the dealer for a real problem.
The recall deals with the vehicle knowing in advance if there will be bubbles in the SBC system, from the number of previous pedal applications. That way, either you would be notified of service being required, or maybe the car being able to handle/fix/bleed the problem... The solution is basically so the driver would not be surprised that the brake by wire system was down due to excessive brake pedal applications.
The problem has only been found in commercial vehicles like Taxis whaich are run 24/7, with many many pedal applications, regulay guy's so the likelihood of a daily driver having the failure at all is remote.
the model applys to
2003 - 2005 E-class and
2003 - 2004 SL-class
equipped with SBC
DaimierChrysler AG has determined that in certain instances the pump motor may run out of permissible tolerances, thereby triggering the hydraulic back up function mode. In the hydraulic back up mode, the driver has braking power sufficient to stop the vehicle, althought greater brake pedal pressure is required and the brake pedal travel will be noticeably longer which lead to a vehicle crash.
Actually, MB must do this recall under US law.
If an authorized Mercedes-Benz dealer or Mercedes-Benz USA, LLC, fails or is unable to perform this service without charge within 60 days, pursuant to law 49 U.S.C. Chapter 301, you may submit a complaint to the Administrator, National Highway Traffic Safety Administration, 400 Seventh Street, S.W., Washington, D.C. 20590 or call the toll-free Auto Safety Hotline at 888-327-4236.
I hope NHTSA knows that US SBC does not have a SBC-hold feature which is a serious safety issue, e.g. vehicle rolls back on the steep hill and may run over the pedestrian behind the car.
I am very UNHAPPY that my dealer takes 2 DAYS to do this 2 hour recall job.
