E-Class (W211) 2003-2009
Dynamic seats!
Old Aug 2, 2023 | 04:52 AM
Peter ST's Avatar
W211 T Model
Dynamic seats!
Hi guys, I have a problem with my dynamic seats on my w211. The passenger side works fine, no problem at all. The driver side not working at all, I’ve checked all the cables, hoses all good, it seems that it has no power, you press the pulse button and noting happens no red light, what it could be? what to check?
P.S. Ive disconnect the hose and the seat has no air leaks
Old Aug 3, 2023 | 01:01 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
flat seat 🙄
Great, you're almost done. Couple more steps in any order you wish it's still free progress :
  • Check fuses
  • scan fault codes
  • compressor/harness test
  • Use schematic diagrams
What do you think is next?
(pardon my ignorance in your airmatic seat) - Hopefully you can get this as it should for luxury rides.
In later years evolution led to driver seats becoming nearly bench-flat, zero-air, crafted with selected vinyls, certified "raised humanly".
Old Aug 3, 2023 | 02:56 AM
Peter ST's Avatar
W211 T Model
  • Check fuses
  • scan fault codes
In later years evolution led to driver seats becoming nearly bench-flat, zero-air, crafted with select petroleum vinyl, certified "raised humanly" guaranteed. Bit by any badic Japanese entry level a very sad sight guys.
Thank you for your reply. I’ve checked the fuse all good, no error codes!
