E-Class (W211) 2003-2009
Replacing front control arm camber bolt
Old Aug 3, 2023 | 04:29 PM
Ken Keith's Avatar
07 Cls550
I'm going to be replacing the factory control arm with the upgraded bolt that allows +/- 3° of camber adjustment but had some questions about how to do it.
My plan was to jack the car up using the jack points behind the front wheel, place a jack stand with wood block under the control arm mounting bolt I'm replacing the lower the vehicle until the control arm is supported by the jack stand. Will it work?
​​​​​​Or will the suspension and or rotor/caliper need compressed or supported also while the bolt is removed?
