E-Class (W211) 2003-2009
Can you add Tire Pressure Monitoring and Distronic after purchase?
Old Nov 4, 2004 | 10:52 PM
epasc's Avatar
I have a 2005 E500 and would like to add these features. Does anyone know if they are dealer installable?
Old Nov 4, 2004 | 10:53 PM
epasc's Avatar
Correction - it's a 2004 E500
Old Nov 4, 2004 | 11:10 PM
hlkc's Avatar
06 CLS500 + 99 ML320
I really want the Tire Pressaure Monitoring in my 05 E500. But my sales told me that it is not retrofit and must be a factory installed item.
MBenzNL Steve and scorchie, can u?
Thanks!
Old Nov 5, 2004 | 01:47 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
TPMS can be added after the fact... it doesn't appear to be terribly difficult.
Distronic... Steve's working on that one. It's mostly installed in my E55 but we haven't had time to activate it yet. Other priorities... Steve believes that it can be added after the fact to the W211 as well, and Sunman did a great job getting it going on his W203.
-s-
Old Nov 5, 2004 | 02:47 AM
miroj's Avatar
The thing about Distronic is that you need a specific version of the ESP module. That particular unit has to come out or be flashed with the newer software.
Distronic
- radar module
- wiring
- main control module
- SPEEDTRONIC + TEMPOMAT (S42) column control switch
(you may as well install the voice control system at the same time)
- new ESP module for BAS control
- drivers control switch (near gear selector)
- new panelling around gear selector.
- Systems Control Number activation code
- Star Diagnostic activation
- radar alignment
- validation of correct horns (one frequency is known to destroy the radar)
- new grille with glass insert for radar operation.
- new hood star ?
As for tyre pressure
It would be a parts kit and is truly bolt on. It would require that all the rubber be removed from your rims also and the pressure sensors with valve be fitted in place of the normal air valve. They have a 7 year life.
Activation isnt so hard with STAR.
Old Nov 5, 2004 | 05:59 AM
guru's Avatar
2004 E320 4matic, 2007 530xiT
What does TPMS cost?
Old Nov 5, 2004 | 06:34 AM
miroj's Avatar
Parts Estimate
Chassis Number:WDB211076 (E55)
Part Number Designation Code Qty Price
A 000 822 34 06__SENSOR____004 401.76
A 211 546 20 43__BRACKET___001 4.68
A 211 546 18 43__BRACKET___001 7.80
A 211 546 17 43__BRACKET___001 7.80
A 211 546 19 43__BRACKET___001 4.68
A 001 827 48 01__ANTENNA___004 111.60
A 211 540 62 07__CABLE LOOM__001 130.05
Approximate Total: 668.37 Euro
This is a sample only. The main loom varies and several clips and bolts are not shown.
Old Nov 5, 2004 | 10:15 AM
hlkc's Avatar
scorchie,
How much will you charge to install the TPMS (parts/labor)?
Thanks!
-s-
Old Nov 5, 2004 | 10:49 AM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
I am also interested in adding TPMS on my 2004 E320 4Matic. When I asked one of the service writers at my dealer (not the one I usually use). He said that the system was integrated to the main coputer and that it would be impossible or too expensive to do.
If anyone does it here in the US, could you please give us the complete list of items needed (I know you have the list already, but since you quoted it in Euros, I am wondering if there might be other stuff needed for the US market) plus how much labor you paid? Than would be great to bring to my dealer and say "DO IT!!!"
Also, since I don't have the system and I have two sets of rims and tires (winter/summer) I guess this means I need to install more sending units in each wheel. But, how does the system know what tire is which after you rotate the tires? Are the sensors in each respective wheel well?
Any imput would be great!
Steve Aguirre
Old Nov 5, 2004 | 03:55 PM
miroj's Avatar
Steve Aguirre
This information comes from the MB database ! GIF attached.
20 - antenna
25, 30, 40 - brackets
60 - wheel sensor
100 - controller
300 - main wiring
200, 210 - replacement parts for connector
Everything else is an attachment part for fitting
Attached Thumbnails Can you add Tire Pressure Monitoring and Distronic after purchase?-tpms.gif
Old Nov 5, 2004 | 04:04 PM
scorchie's Avatar
Distronic
- radar module
- wiring
- radar alignment
- new hood star ?
Add one more thing to your list:
Right side carpet. The module sits under the carpet and on cars with Distronic, the carpet backing has a cutout for the module. Fits much better that way!
-s-
Old Nov 5, 2004 | 04:27 PM
miroj's Avatar
-s-
Dont they have knives in California ? I guess you could always carve out the backing with an Uzi.
Old Nov 5, 2004 | 06:04 PM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
Sometimes humour doesn't travel to well, have you seen this link?
http://www.snapsandbytes.co.uk/video38.html
You will need to have the volume turned up. It is not rude, or offensive.
Take care,
John
A cold dark night in Torquay
Old Nov 7, 2004 | 07:31 PM
scorchie's Avatar
I did it with a knife. And although my cutting skills are usually pretty good, I think a better fit would have been obtained with the proper carpet...
The three Uzis I have (Israeli, Chinese and US manufacture) probably would have yielded worse results! I would bet the US version would produce the best cut line.
Seriously, in the US we can probably buy the carpet with the money we save by not purchasing these items... they are unneeded here as the devices fitted for US-spec are sufficient.
- new hood star ?
-s-
Old Nov 7, 2004 | 08:16 PM
miroj's Avatar
- new hood star ?
-s-
Im not convinced about the S42 replacement, I understand that I will enhance the functions.
As for the ESP module ....... that really comes down to the type of module in use. Some variants come with all the necessary code. Validation is the key if you consider the W203 and W209 as possible applications.
Checking the horns doesnt seem to be any special effort ?
