Ticking noise between 6k and 18k RPM at startup
2004 E500, 2001 BMW X5 4.4
I realize this is probably just paranoia, but I noticed a ticking noise between 6,000 and 18,000 RPM at startup. Not coincidentally, the temperatures here have dropped down around 40 degrees lately, much colder than have been the case until recently. The noise seems to decrease over time and once the car has warmed up I barely notice any noise, except at around 15,000 RPM where I can still barely pick it up.
Is this a matter of letting the car warm up or should I be worried? Does my description match other E500 owners?
2004 SL55, 2005 E500 Wagon
F1-scale revs in an E500
Originally Posted by champaigntaste
...I noticed a ticking noise between 6,000 and 18,000 RPM...
Jim
2014 C250 sport
As for the ticking noise, my dad's 03 ML55 does that when it's started when the engine is cold(sometimes), and so does my grandma's 01 SL500, so I don't think there's anything to worry about
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
I was going to say. . . I am surprised that it is only a ticking sound at 18,000 RPMs.
I have an E320 and it ticks a bit when the garage gets under 40 degrees, but it only lasts about one second. The ticking never has never lasted longer. If it makes you feels any better, my AUDI with 260,000 miles (this is the correct mileage) ticks for about one minute at all RPMs when it sits outside and the temperatire is below 20. It has done that since day one so I am not really concerned about it. I just drive them right away and don't rev them past 2000 rpms for about 1 mile or so. I am lucky because my house location lets me do that without people lining up behind me. I think that is partially why my AUDI has lasted so long.
Steve A.
Steve A.
I think it is a characteristic of this particular engine. The same 18-valve 3.2L V6 in the W210 chassis made the same sound. I wouldn't worry too much about it.
2003 E 500 - Full option
Mine is doing that noise after being kept stored for more than 2 weeks.
I suspect that it comes from the oil which in your case is frozen and in my case fallen in the bottom of the engine and which do not lubricate any more the cameshaft and the cam chain. Anyhow, it disapear after 30 seconds.
SL500 E320 ML350
I had the ticking noise on start up but also after some drive time as well. When my service manager listened he thought it might be a lifter. He pulled the valve cover and then the heads and found some strange wear marks on the cam shaft and rocker arms. I'm now having them all replaced. The MB V8 should NOT be sounding like a sewing machine at any rpm! I've had two previous Benz V8s and both were Rolex quiet. Have someone look at it!
![action](https://mbworld.org/forums/images/smilies/action1.gif)
'07 Porsche 997TT
Most of the posters on this thread seem to be relatively new here. Some may not be aware but many of the '03 W211 had a "ticking" sound. There was a service bulletin out for this and it involved replacing the motor mounts. When I had my '03 E500 I had this and they were changed. Not sure if the problem still exists, but curious as my E55 is "ticking" a little these days.
Interesting....my 2001 C320 had a very distinct ticking when it was cold. I thought it sounded like a lifter and asked them to check it, but was told it was "normal." I haven't noticed this sound in my new 05 E320.
Thanks for the responses. I will query the MB service department when I have them perform the brake recall service tomorrow morning. Thanks.
SL500 E320 ML350
'07 Porsche 997TT
Originally Posted by benzboy
FYI, did the motor mounts and replaced the belt tensioner - ticking still there. Now they are doing the work I described above. I'll let you know how it worked on Friday! ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
