722.6 Pilot Bushing Life
How often would it be necessary to replace the pilot bushing. When I replaced it (~120,000 mi.), now 205,000 mi.? I suppose I should have asked this before I just did a whole flush.
Hi ot1, I hope this helps.The pilot bushing is not an item that typically requires frequent replacement as part of regular maintenance. It's designed to last a long time under normal driving conditions. However, its lifespan can vary based on driving habits, clutch use, and environmental factors.
Replacement intervals for the pilot bushing depend on several factors:
If you're experiencing clutch-related issues or suspect problems with the pilot bushing, it's best to have a professional mechanic inspect it during your next clutch service or maintenance check. They can determine its condition and advise if replacement is necessary.
- Driving Conditions: Frequent stop-and-go driving or heavy use of the clutch may wear down the pilot bushing faster.
- Maintenance History: Regular clutch inspections and replacements could indicate if the pilot bushing needs attention.
- Environmental Factors: Extreme heat or contamination from dirt and debris could affect its lifespan.
Part number 2035400253.
