I have a 2005 E320 loaner and noticed..
2004 E500 / 2001 C240
I noticed that the snorkle on the 2005 E320 has little air vents that are filtered half way down the snorkle (inside the engine comparment). Also, both of the snorkles are the same size, left and right.
Anyone put these on the E500? Would this make a difference as it might be able to pull in more air?
Also, anyone with a 2003 or 2004 E320 have that? How about the 2005 E500?
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
My 2004 e320 has both snorkles that are the same size. Aren't all??
I don't know what you are talking about when you mention the thing about he filters. The snorkles are just a tube, nothing inside of them. The filters are in the big housing on top of the engine.
Does this answer your question?
Steve A.
Steve A.
The small slits or vents in the air intake tubes are an interesting feature. Some say that it will prevent water from entering the engine as the water will fall through the vents. Others say that the vents help aid engine breathing at idle rpms since the engine does not have to suck air from the front of the car.
2019 Mercedes Benz S500L AMG Premium Plus
Some say they are a pain in the butt too as they allow you to draw up standing water during inclement weather.
It would have to be more then a foot as it is just below the hood.. 3 feet?
Those with 2005's open the hood. Does the two air intake tubes (that come from the grill), in between the grill and the engine, are there little yellow mesh holes in the center? In particular the 2005? In the 2003 and 2004 it is just a straight black tube and the right one (driver side) is smaller then the left side for some strange reason. Many people change the driver side on the large one that comes with the SL500..
The purpose of those vent screens is for noise suppression. They are only present on the E320. Don't ask me how it works, I don't know.... I was just told about them in training. They don't do anything else, all of the above mentioned theorys are incorrect.
The E320 also has the air door in front of the radiator that will close at driving speeds. The E500 does not have this. When you have a V-8, you want to hear the engine; and a minute increase in fuel economy is not of concern.
As for noise suppression, I suppose that is possible. My guess is that it might reduce resonance with the long intake tubes by splitting the airflow path with the vents. However, this " air door in front of the radiator that will close at driving speeds" is nowhere to be seen on my particular 05 E320. I've seen the pdf which show how it works, however I've checked all over my engine bay and I do not see it. Anyone want to post a picture of where it is? Also the logic in regards to the door does not make sense. If the purpose was to increase the sound of the engine, why would it be in FRONT of the radiator as opposed to somewhere closer to the firewall?
The vent screens pictured on the intake tubes are what I was referring to regarding noise suppression.
Thank you for the pic. Now I know that I, at least, was talking about the same thing.
Steve
Steve
