E-Class (W211) 2003-2009
Thud noise from rear axle area when letting off power
Old Mar 2, 2024 | 01:51 PM
dannyfiveforty's Avatar
2008 CL63 AMG
I have a 2008 211 estate. Thud noise only when abruptly letting the power off. No noise what putting power on.
A one time only thud from the rear when the accelerator is let off. I have had a bar in there and nothing is obvious. Mercedes Benz dealer looked it over and said it could potentially be the sub frame bushes or the flex disc. I have so far changed the disc which was very badly split, however, the noise is still there.
As a process of cheapest/easiest job by elimination what should I do next?:
a. Subframe bushes look to be ok with a bar in there and understand a very labour intensive job...
b. Change the diff bushes..
c. Change out the entire diff incase of play, But play I have been told is perfectly normal to have a rock back and forward (noticed when changing out the flex disc)
d. Anything else I could potentially try to isolate the noise? Or any potential cause I have ovelooked?
e. Exhaust isnt moving around and is not the cause.
f. My car is RHD and from driving seat the noises seems to be coming more so from the rear left. But, that could just be acoustics in the car and my seating position that is play tricks with me..
Many thanks
Dan
Old Mar 3, 2024 | 04:57 PM
2008 CL63 AMG
Originally Posted by Plutoe
have you looked\listened to the drive shaft while on a lift or is this a living room couch diagnosis
when you say listened. Do you mean axle stand the back wheels and put the car in drive and chop the pedal whilst someone is underneath?
Old Mar 4, 2024 | 07:23 AM
2008 CL63 AMG
no I mean a lift, like in a normal garage, its done all the time,whats the problem---money
I would have assumed Mercedes Benz would have done this??
I guess i should just do subframe bushes as they recommend. Just bugs me that they said flex disc, which made no difference.
also, would hate to do bushes for it to make no difference and then come here and someone point out something obvious to check.
thanks
Old Mar 7, 2024 | 05:10 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Probably a worn bushing/bushings. A visual inspection should help a lot. And indeed, if you dont have faith in that same party, go somewhere else for a second opinion
