E-Class (W211) 2003-2009
Transmission issues
Old Mar 8, 2024 | 08:32 PM
Nancypants's Avatar
E350 4matic
Transmission issues
Hello all. I'm new to the forum so please bear with me. I have a 2008 mercedes e350 4matic that I'm having transmission problems with. So this is what's its doing. I get into the car and I can drive for about 10 miles or so then if I'm at a stop and press on the gas pedal it acts like it's in neutral. It will not move at all. If I turn off the car and start it up again it will move a short distance. If I turn off the car and let it sit until cold again I can drive it 10 miles or so before it does it again. The car does not show overheating in the dash. Any ideas ?
Old Apr 5, 2024 | 09:02 PM
stardamore's Avatar
2006 W211 E200
The absolute first thing you should do is get your transmission fluid levels checked. See if they're low or not as that would be the most likely cause.
