E-Class (W211) 2003-2009
2006 E500 not starting
Old Mar 25, 2024 | 10:38 AM
connord's Avatar
2006 E500 4matic
Just got gas on Saturday and went to start it then the car would crank and start for a couple of seconds then shuts off and now that I tried starting it today it just cranks and now it won’t start at all and just keeps cranking also it’s now telling me low battery convenience features temporarily disabled but it does that every time it’s under 30 so I didn’t really worry about it since I got a new aux battery just over a year ago now and I’ve been reading around and it seems like it’s either a cam position sensor or crank sensor idk if they’re the same or not but but I’m hoping it’s that but was looking to see if anyone had any other thoughts on the matter
Old Mar 25, 2024 | 01:13 PM
liljojo12347's Avatar
2005 E500(w211) with a 5.0(B113)
your crank, and cam sensors are different. I had the same problem with my car, try unplugging your battery for one minute and then plug it back in and try starting it again. If it cranks up and doesn’t want to start or starts for a second then dies again try starting it with your gas cap off, or throw it into neutral and try to start it again so you can eliminate your park sensor and your system. Let me know if that works or not, good luck bud.
Old Mar 26, 2024 | 10:43 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Have you scanned it for codes? Until then we're all guessing.
Old Mar 26, 2024 | 01:27 PM
Heguli's Avatar
2006 E280
If it already cranks on park, issue is not on the P/N sensor.
Old Mar 27, 2024 | 11:20 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
My best guess for now is crank position sensor
