E-Class (W211) 2003-2009
E85 2005 E500 with B113 engine
Old Mar 25, 2024 | 01:18 PM
liljojo12347's Avatar
2005 E500(w211) with a 5.0(B113)
does anyone know what I need to change to run E85 if anything other than tune. Can I run it with the stock fuel lines and fuel pump and injectors or do I need to change it all out?
thank you very much.
Old Mar 25, 2024 | 10:23 PM
Originally Posted by Plutoe
Base on that suggestion, i would change girlfriends and go to the library and start to read a good auto engine engineering book that stresses design based on low octane gas or sell the car because you will need much more than a tune to maintain factory engine specs
are you dumb or just a dick? I not only tune cars, but build cars for a living. They are plenty of cars that you can run E85 on with a tune only. I’m not new to the building or tuning world. I’m just new to this platform so I was asking questions to familiarize myself. It was a simple question and you don’t need to be a dick, all you had to say, is no you can’t or yes you can run it on the stock system..
Old Mar 26, 2024 | 08:56 AM
tjts1's Avatar
C320
If you're such are great expert why are you asking?
Old Mar 26, 2024 | 10:40 AM
Heguli's Avatar
2006 E280
You could go with this for example: www.eflexfuel.com Has everything you need, should be good to go with stock parts. One important part is the fuel sensor, which senses the ethanol content and adjusts fueling accordingly.
