E-Class (W211) 2003-2009
HWY, motor oil everywhere smoking no check engine
Old Mar 29, 2024 | 06:02 PM
brewtownwi's Avatar
MB 2007 E350
Hey, wonderful world and friends. I was driving on the highway in the USA and my motor started smoking and there’s oil everywhere under the hood. I got a slow drip now that I’m parked on the left side facing the front of the car.
I’m currently waiting on the tow truck and just wondering if anyone might have an idea what would cause the oil leak without a check engine light? The car still starts and runs good obviously I’m not gonna drive it but there’s oil everywhere.
Old Mar 29, 2024 | 06:03 PM
brewtownwi's Avatar
MB 2007 E350
Old Mar 29, 2024 | 06:07 PM
brewtownwi's Avatar
MB 2007 E350
Video
video
File Type: mov
Old Mar 29, 2024 | 06:36 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
I suspect oil filter housing and the 2 lines running to/from it. That is the highest point for the oil flow. Might also be the oil cooler below the intercooler or the secondary oil cooler in the passenger footwell
I just posted a video on how to remove the oil filter housing.
Old Mar 30, 2024 | 09:21 AM
brewtownwi's Avatar
MB 2007 E350
https://www.youtube.com/watch?v=j_PCgjmoJuI
thanks bro. The other issue is I’m in the middle of a small town with though Mercedes mechanic
Old Mar 30, 2024 | 09:22 AM
brewtownwi's Avatar
MB 2007 E350
Pics
Old Mar 30, 2024 | 09:23 AM
brewtownwi's Avatar
MB 2007 E350
Pic
Old Mar 30, 2024 | 09:24 AM
brewtownwi's Avatar
MB 2007 E350
pic
File Type: mov
Old Mar 30, 2024 | 09:55 AM
streborx's Avatar
Top Answer: 1
G550
Did you recently have your oil changed by a mechanic who cranked down the oil filter cover with somewhat over-exuberance?
Old Mar 30, 2024 | 06:56 PM
brewtownwi's Avatar
MB 2007 E350
Oil change
negative. The only mechanic that touches my car is precision motor cars in Cincinnati Ohio.
but I will have them check that out. Unfortunately I gotta head back home and I’ll have to call about the car on Monday.
Old Mar 30, 2024 | 07:05 PM
Keep us in the loop, good luck
Old Apr 3, 2024 | 12:47 PM
brewtownwi's Avatar
MB 2007 E350
4/3/2024 Update. State Farm towed the car from Marchall, Michigan to Kalamazoo, Michigan. MB said they couldn’t look at it until 5/2/2024.
will update then. 🙄🙄🙄🙄
Old Apr 3, 2024 | 01:04 PM
streborx's Avatar
Top Answer: 1
G550
They could have spared 5 minutes to roll under your car to assure you that you didn't have this guy's problem.
https://www.facebook.com/watch/?v=482770369567673
Old Apr 4, 2024 | 10:45 AM
brewtownwi's Avatar
MB 2007 E350
Hi,
tech in Kalamazoo advised the oil filter seal broke.
last oil change was a few months ago at 136,000 miles. Currently has 141,000.
drive to Michigan and back a few times this past few months from Cincinnati, Ohio. About 300 miles each way.
odd that it would break driving down the highway don’t you think?
Old Apr 4, 2024 | 10:53 AM
streborx's Avatar
Top Answer: 1
G550
Hi,
Is this the seal (the o-ring) that's installed on the plastic oil filter cover?
Old Apr 4, 2024 | 11:35 AM
tjts1's Avatar
C320
Hi,
Nope.
Old Apr 4, 2024 | 12:29 PM
brewtownwi's Avatar
MB 2007 E350
yes, I do believe but I’m relaying info from text messages. I’ll confirm all details soon and update description on thread to help others.
Old Apr 4, 2024 | 02:08 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
If it is that o-ring, it can get pinched if the installer doesn’t put a thin film of new oil on it before tightening. Also, in a worst case, if the cap is cross threaded and forced down, eventual failure is almost assured. Ask me how I know.
Old Apr 4, 2024 | 02:42 PM
streborx's Avatar
Top Answer: 1
G550
I've read about over-zealous oil service techs who over-torque the filter cap, and fracture the plastic. I'm not sure how susceptible the cap is long term to heat cycling stress, but I keep a spare in my box of filters just in case.
Old Apr 4, 2024 | 03:02 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Could also be the o-ring between the oil filter housing and engine block. Requires a 46 or 47mm socket to replace. Happened on both my W210 and W211 E55s. Nothing quite like crawling under the car and thinking, "Where did all this freakin' oil come from"?
Old Apr 5, 2024 | 08:17 AM
I am just uploading videos about this service, but its for the W211/W219 55 AMG.
