E-Class (W211) 2003-2009
Still Think I Have Intermittent No Crank Keyless Go Prob
Old Nov 17, 2004 | 10:38 AM
Barry45RPM's Avatar
2015 ML 350
Every so often I get in & press the button & I get a momentary crank & then nothing except an SBC malfunction warning on the speedo. I have to turn the car off ,wait, & try again. Usually then it will crank & start fine. (SBC warning dissapears with a proper start) Last night that happened, and I got my 1/2 crank & then silence. Tried to start it with the key and got no cranking at all. I had to wait a few minutes trying between the key and keyless. Finally keyless worked perfectly.
Dealer says there is no known problem like this, and to be sure I have pressed down on the brake pedal really hard before pressing the keyless button.
Any one else?
