E-Class (W211) 2003-2009
Focus headlights
Old May 25, 2024 | 06:31 PM
GR947's Avatar
E320
Focus headlights
Hi I have a question about my e320 2005 is there away to focus the headlight beam . The head light is at the same level as eachother but the beam on the drivers side doesn't seem too be as sharp ie out of focus is there away to adjust this at all please thanks
Old May 26, 2024 | 04:39 AM
Heguli's Avatar
2006 E280
What type of bulb (halogen or xenon) you have, and what's the condition of the lenses?
Old May 26, 2024 | 08:49 AM
GR947's Avatar
E320
Hi they are xenon bulbs lenes are both ok
Old May 26, 2024 | 02:36 PM
Heguli's Avatar
2006 E280
Probably the xenon bulb on it's way to die. I changed the RH bulb because it was rather dim, and you could say it was out of focus as the light pattern didn't have as sharp edge as the left had.
Old May 27, 2024 | 07:59 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Either the bulb is about to die or the projector is burnt
source: https://retrofitlab.com/blogs/news/m...non-projectors
I had the same/similar issue on my 2005 CLS55 and replaced both headlights. Light output and sharpness have both increased dramatically.
You can also replace just the projector, but as the interior wiring also becomes brittle and will cause errors, I opted for totally new units. More info + pics in my build thread: https://mbworld.org/forums/c219/8443...ml#post8889206
