E-Class (W211) 2003-2009
Question regarding A/C w211
Old Jun 10, 2024 | 01:10 PM
muhab94's Avatar
w211
Hello
I hope everyone is well.
I have questions regarding the AC in MB W211 E220 CDI E/S 2009 (UK Reg). I bought this 50k miles MB about 4 months ago.
1. Apparently, the compressor I have is 6SEU16C or 7SEU17C. The compressor pulley keeps spinning even when the AC is off. are these models VDC/clutchless? Should the pulley stop spinning at all?
2. The blown air seems to be cool whether the AC button is on or off. I tried resetting it, putting it on auto, and turning it on and off. Nothing changes.
3. I cannot detect any sounds when turning the AC on and off, pretty much the same engine sound and speed. The only thing that changes the RPM is turning the whole climate control on and off.
4. I recharged the Freon recently (about 3 weeks ago), but the AC is not cooling well. The weather is not really very hot in the UK. I believe any AC should cool better in these weather circumstances. when I first bought the car there was no Freon in it and the AC button was flashing red light and auto-switching off. It worked after recharging it and resetting the codes
I am going to take the car to the service station that charged the gas to check if it is still holding the charge but i am worried that the compressor or any other components might be faulty. I would appreciate your input.
Apologies for the prolongation and many thanks in advance.
Old Jun 12, 2024 | 04:22 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
get the fault codes using MB compatible scanner.
Keep in mind that a bad cabin filter won't blow through A/C evaporator and cause it too freeze easily.
Overcharging degrades the low side pressure circulation.... more refrigerant IS NOT BETTER.
These compressors keep spinning with serpentine belt regardless of clutch cycling on/off.
BEWARE of refrigerant hazards... it can freeze burn eyes and fingers. Don't mess with it.... SCAN the air con module
