E-Class (W211) 2003-2009
Trou a l'accélération e320 CDI
Old Jun 21, 2024 | 09:23 AM
Nezir's Avatar
E320 CDI 2008
Bonjour a tous, j'ai un E320 CDI de 2008 (W211) et j'ai remarqué que lorsque j'accélère et que le régime moteur atteint les environs 3000tr/min, il ya comme un trou dans l'accélération pendant 1 seconde puis après ça le régime moteur re continue de monter, pourriez vous m'aidez a savoir quel est la cause de cela? Merci bcp
Old Jun 21, 2024 | 10:20 AM
tjts1's Avatar
C320
Do you have any DTCs?
Old Jun 21, 2024 | 02:07 PM
Nezir's Avatar
E320 CDI 2008
Hi i'll do it tomorrow, i dont know if it will find anythings..
Old Jun 21, 2024 | 02:47 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Good day to you all. I have a E320 CDI 2008(W211), and I have made a remark(observation)at the time I speed up, and at the vicinity of the engine running at 3000rpm, how there comes a pause(hole;empty space) in the acceleration at the same time 1 second after this engine rpm continues to increase can you help me to know what is causing this here?
Thank you very much.
My French is not very advanced so, pardon me if I am translating poorly.
Old Jun 22, 2024 | 12:41 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
is this CDI a diesel or gas engine?
Old Jun 22, 2024 | 08:35 AM
Heguli's Avatar
2006 E280
CDI = Common rail Diesel Injection.
Old Jun 23, 2024 | 12:50 AM
I would read the fuel rail pressure and/or check fuel filter replacement schedule.
Use a good scanner to check all faults.
