E-Class (W211) 2003-2009
w211 Command Not Opens
Old Aug 6, 2024 | 03:05 AM
dartagnan's Avatar
2004 w211 e320
My 2004 E 320 has the attached command. It was working well until I connected an AUX cable to device last week. So, command doesn't open when engine starts for almost a week. I drive a few miles then it works.
Some findings:
- Battery voltage seems good.
- Auxilary battery is new.
- There is no electric leakage.
What do you recommend?
Old Aug 6, 2024 | 04:50 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
What happens when you disconnect the AUX cable again? Just for testing if the issue is somewhere related to that cable
Old Aug 6, 2024 | 05:02 AM
dartagnan's Avatar
2004 w211 e320
Actually, this will be one of the last steps that I was going to try. Since It is a lot of work to disconnect it since the cable is behind command. I need to unmount gear stick cover, fire lighter part, cd changer, command and I dont want to lose my cable because it is very useful. I am pretty sure that command was working fine. It is definitely related with the cable connection but why? Is it something like short circuit or electromagnetic field?
Old Aug 6, 2024 | 05:36 AM
Might also be related with some other cables on the back of the Command unit, when you have been working on it
Old Aug 6, 2024 | 05:55 AM
dartagnan's Avatar
2004 w211 e320
Well, this is good point. While working on it, I have seen some red, yellow, cables hanging out behind command. Those cables were belong an android unit from previous owner. Do you think those cables cause this?
Old Aug 6, 2024 | 06:33 AM
Hard to say, but could very well be, who knows...I don't like cutting up/modifying original wiring. Because the Command unit is such an integral part of the car, I made the decision to keep it original in my CLS55
