E-Class (W211) 2003-2009
2006 W211 E55 AMG Rear Camber Options: SPC?
Old Aug 8, 2024 | 10:12 AM
Kapok6's Avatar
Perspective E55 AMG
I am looking into various options for adjusting the camber on my 06 E55 AMG. I came across this SPC bushing replacement kit for the W211:
https://www.ecstuning.com/b-spc-part...ing/28860~scp/
https://goturbo.net/spc28860-spc-per...mber-kit-28860
But the E55 AMG is not listed as one of the applicable vehicles.
That being said, is there a difference in the control arm between the 320, 350, 550, etc and the E55 AMG that would make these not work?
If Indeed those will not work, I was looking at the Megan Racing adjustable arms:
https://coiloverdepot.com/products/0..._mM8ElFwCw8q70
And found these on eBay https://www.ebay.com/itm/22586497332...3Avlp_homepage
Any thoughts or experiences on those?
Old Aug 8, 2024 | 01:21 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
The AMG E-class version uses 14mm bolts to attach the upper camber arm to the hub. Non-AMG E-class vehicles use 12mm bolts. SPC kit uses 12mm bolts. I got this information in a phone conversation with one of SPC's design engineers.
Easiest way to ensure you have correct camber is to ensure the air suspension is properly calibrated for ride height.
Old Aug 8, 2024 | 01:39 PM
Kapok6's Avatar
Perspective E55 AMG
Thanks for the response. I am converting to coilovers, which is the reason for my inquiry. So it looks like aftermarket arms would be the only solution then as it appears that asife from K-Mac, bushings are not available.
Old Aug 9, 2024 | 04:28 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
FOR THE W211 (ALL MODELS) WE MANUFACTURE A “TOTAL SYSTEM” !
Proudly having “IN-HOUSE” manufacture (not sourcing imports) allows us to have total control over quality and rapid, constant design upgrades, improvements.
Latest design breakthrough is both the Front (Camber and Caster) kits and the Rear (Camber & extra Toe) kits - No special tools or time consuming need for control arm removal to install.
SEE SPOILER - TOTAL SYSTEM
Spoiler
AUDI to VOLVO - Experience Resolving OEM Suspension Shortcomings (and costs) Since 1964 !
Old Aug 9, 2024 | 06:38 PM
Kapok6's Avatar
Perspective E55 AMG
Aside from the adjustable camber arm, I am going to replace the other arms with stock arms. To make sure I am getting the correct arms, do the adjustable arms replace 2113503106/2113503206, or 2113502906/2113503006?
