E-Class (W211) 2003-2009
2003 E320 Android Radio Install - No Power to the Radio
Old Aug 8, 2024 | 02:20 PM
darkeccho's Avatar
w211 e320
I've been attempting to upgrade the radio in my Mercedes Benz 2003 W211 E320 as the old one wasn't actually working when i bought the car.
I assume the issue with the old radio is the disc drive as the logo comes on, you can hear the disc drive trying to do something and then the radio shuts off.
As such i decided to purchase this radio from Ebay as it stated it was compatible with my car and i saw a video of it actually working on YouTube:
Ebay Item: https://www.ebay.com/itm/235320763763
YouTube Example:
I also watched a few YouTube tutorials which didn't exactly cover all the steps needed or this exact model but was similar in various ways:
Exact Model Tutorial (missing certain install steps):
Different Model Tutorial:
The Issue:
Upon receiving the radio i attempted to install it, however it seems the connection cords they sent me are not the same as the instructions images they provided.
Instruction image: https://shijiazhuangpack.oss-eu-cent...WDBENZB200.jpg
The Actual cords i received (this image is from the ebay listing):
Model C being the 3rd cord from the Left, however in the instruction image it looks completely different, so for some very odd reason the company provided me with either an old version of their instructions or the wrong instructions and even when i asked them to update the image for the correct cords, they just kept sending me the same image over and over again, which was not helpful at all.
According to the company the Green wire is the one that provides power to the radio unit, however there is nowhere to plug the Green wire into, so i have been unable to get power to the radio. I even attempted to plug the Green wire into the port under the passenger glove box but it does not fit, as it has a different end.
Example Images:
Cords A & B:
Cords (Unlabeled):
Cords (C - Installed) :
Cords (C - label):
Radio (No Power):
Conclusion:
As you can see i am using the version C of the cords since that's what fits with my car and the end for the Green wire for the version C clearly is not flat like the unlabeled version, so it will not fit in the port under the passenger glove box.
At this point i am stumped, i have no idea how to get power to this radio and no matter what combination of wires i attempt to use, i can't get it to work.
Has anyone attempted to install this type of radio in their Mercedes Benz 2003 W211 E320 or has an idea of what the problem could possibly be? I would be greatly appreciative for any insight, thank you!
Old Aug 9, 2024 | 06:44 AM
Rob E.'s Avatar
04 mercedes-benz e320 4matic
I have 2004 e320
YouTube Example: https://www.youtube.com/shorts/yZR3Iozf1L8
Exact Model Tutorial (missing certain install steps): https://www.youtube.com/watch?v=u9CXkuAPens
Different Model Tutorial: https://www.youtube.com/watch?v=zJALScfHdBI
The Issue:
Example Images:
Cords A & B:
Cords (Unlabeled):
Cords (C - label):
Radio (No Power):
Conclusion:
I have 04 e320 was pretty close to yours but in my version was xtrons radio it looked like a combination of them either way I did a complete install speakers amps the hole 9 yards and took me forever in mine nothing was plug and play had the Harmon in their so I used the fiber converter at first the green wires are for your steering controls and to tell you what door is open etc. i am a little confused what your asking now you can run them to the canbus hub and t tap in just extend the wires if you have too. I will help you just let me know exact questions
Old Aug 9, 2024 | 12:34 PM
darkeccho's Avatar
w211 e320
Nah the green wires have been specifically stated by the company i bought the radio from, that it provides power to the radio unit.
And i specifically asked where to plug the green cord into, as it's crucial to the function of the radio.
Old Aug 9, 2024 | 02:22 PM
Rob E.'s Avatar
Spoiler
Old Aug 9, 2024 | 02:56 PM
Rob E.'s Avatar
I just red the instructions they gave you clearly pics and all green wires going right to can h and can l hub. That's is not power like I said red yellow constant 12v red acc it tells you clearly to find acc source cig lighter is best I found and brown ground. Maybe get volt meter and go to a shop if this is not clear
Old Aug 9, 2024 | 03:05 PM
Rob E.'s Avatar
Green u scan h and low can't you see the pics they gave ypu
Is thay crucial enough for ypu or shall i add more pics of mine working 100 percent they were clear i see in instructions ypu should go to installer my friend also the videos that ypu choose on ypu tube are prob the worst ones the one is all plug and play ypu dont have that brand readio the others well as ypu see check out panzar w211 mercedes and he explains good look at mine as well ypu tube i have videos from install to how to code your car with xentry still learning how to film.basic stereo
