Does anyone have panorama & parktronic?
Thanks.
On the display, the headliner has a recess in it where the hole for the display is cut. That would be more accurate to use than any measurement.
-s-
With the panorama, the EPC calls for a plastic spacer/clip the display snaps into. I was hoping to see a picture to verify if this is the case.
Yes, there's a spacer at the base of the display. To keep the back of the display from poking up too high, I imagine. But it looks the same as the display fitted to the non-PR car I am looking at, as well. Maybe the non-PR cars use it as well? My EPC is traveling around Chicago right now so I can't take a look.
I highly recommend removing the headliner to do the install. Otherwise, you may crease it, or when cutting the hole, one slip could cause other problems.
If you have a good relationship with your dealership, you can ask them for WIS document AZ54.65-P-0001-05T which details installation of the display itself. The overview of the whole backup aid system is covered in document AZ54.65-P-0001T, which references numerous other documents for the steps (you should try to get all of them, or at least ones for areas you may have trouble). There aren't document covering retrofit of Parktronic because MB only supports retrofit of the backup portion, which by itself is not Parktronic.
Ah, further searching uncovered document AR68.30-P-4300-04T, which outlines preparing a headliner for PTS display in a PR car. It mentions something about a new installation frame, but this is used for both PR and Sunroof cars.
-s-
Cutting the hole in the headliner for the rear display is hard enough......next I need to figure how to cut the dash for the front display!!
-s-
