E-Class (W211) 2003-2009
Mystery squeals
Old Aug 20, 2024 | 02:12 PM
KCe550's Avatar
2008 e550 base WDBUF72X98B228774
Mystery squeals
Strangest thing… I unlocked my 2008 E550 while walking toward it in a parking lot today and a loud squeal came from the front of the car. I opened the hood to confirm it was indeed coming from my car and to trace the source. Might have been front left side but it was hard to tell. The squeal sounded like the sound of a loose belt on an older vehicle but no belts were visible and the engine wasn’t on. It lasted about twenty seconds and then faded away. I seem to remember also hearing the sound of compressed air being released, which I've noticed on other occasions.
I’m new to this car and Mercedes and didn’t expect that. It didn’t happen at my next stop/parking instance, but did squeal again briefly when I turned the car off in my garage.
What is this?
Old Aug 20, 2024 | 02:25 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Do you have air suspensions aka AirMatic ?
The chassis height is managed by air compressor and sensors that can develop repair needs.
You can read OBDII computer faults with a handhelp scanner to confirm the health report.
Old Aug 20, 2024 | 02:45 PM
KCe550's Avatar
Thanks, yes my car has some kind of air suspension which was allegedly repaired about a year ago. I will try the code scanner trick per your recommendation.
Old Aug 20, 2024 | 03:32 PM
KCe550's Avatar
Could it be the SBC system?
Old Aug 21, 2024 | 07:57 AM
Heguli's Avatar
2006 E280
No SBC on a 2008 car, it was dropped with the face-lift in 2006.
Old Aug 21, 2024 | 10:12 AM
E500 AMG Sport's Avatar
The sound happened after hitting the unlock button?
Probably a bad alarm siren which also makes a sound when locking & unlocking the vehicle.
Try pressing the Panic button on the remote and see what happens.
Siren is behind the driver front wheel well liner.
Old Aug 22, 2024 | 05:44 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
In that little box. This picture is from my W219 chassis, but should be similar/identical
