E-Class (W211) 2003-2009
W211 No hot air after changing heater valve
Old Sep 13, 2024 | 02:54 PM
BenyMax's Avatar
Angry W211 No hot air after changing heater valve
Hello i had problem with air, my rear wents started to blow hot air randomly. I changed brand new valve under the wipers.
The car started to blow air like i want, but randomly gone up the hot air, but is go down back.
I put the car to diag, deleted all dtc-s, and stopped working only blowing cold air.
I have only one DTC: 'Heater Booster' -Permanent, 9470.
I checked all fuses.
Old Sep 13, 2024 | 02:57 PM
jimyj's Avatar
E320
The persistent DTC code 'Heater Booster' - Permanent, 9470, suggests that the heater booster itself might be malfunctioning. Common causes for your problem include a faulty heater booster unit, malfunctioning temperature sensors, or issues with the blend door actuators that regulate airflow between hot and cold. Even though you've replaced the valve under the wipers and checked all the fuses, these components could still be the culprits behind the random hot air from the rear vents. Using a good diagnostic scanner can really help pinpoint the exact issue. I've found that the youcanic scanner is quite user-friendly and excellent for DIY repairs, providing detailed fault codes and live data. Xentry is another powerful tool, though it can be more complex to use. Having a reliable scanner might help you diagnose the problem more accurately and get your climate control system back to normal. Hope this helps, and good luck resolving the issue!
Old Sep 13, 2024 | 03:09 PM
BenyMax's Avatar
I have XentryDAS. I will check it tomorrow what was the problem.
Old Sep 14, 2024 | 02:39 AM
BenyMax's Avatar
Originally Posted by Plutoe
if you have DAS Xentry what the reason for your post???
i connected the car i tested aux heater, and is says faulty, started to test it amps slovli goes up to 20-40-60amp and after that shows the preheat modul is faluty and amps goes up to 255a.
Old Nov 20, 2024 | 07:20 PM
yando51's Avatar
2009 E350
I have a similar problem and no codes, Did you fix yours?
