Sport Mode vs. Comfort Mode in E500
1 Post
'08 AM Vantage V8 - '03 E500
Originally Posted by SAguirre
The most important feature of the C mode is always overlooked!
If it is icy on the roads, the last thing anyone, 4 matic or not, should do is engine brake. In S mode, when you let go of the gas it tends to do a lot of engine braking. NOT GOOD!!!!!!!! If you are engine braking and your wheels lock up due to ice, then you have no electronic control to stop the skidding (other than esp). Under bad traction conditions, C mode will coast and NOT engine brake. Then this lets you use the normal brakes and then the ABS can unlock any wheel that hits ice.
and try it out, the next time it snows there.
1 Post
w211 & w124
Originally Posted by Otto
S is "Standard" mode, not "Sport" mode. W211 is not a sports car -- you cannot switch gear manually, can you? (amg model only provides you more power, what can you do after kicking down?)
C is "Comfort" mode or called W "Winter" mode which starts from the 2nd gear.
I believe C/W mode consumes more gas but it is more comfortable, especially, US W211 does not have a SBC-HOLD feature, C/W is another alternative to hold your car in a steep hill without rolling back.
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Originally Posted by Samoan_Ridah
Although "S" mode is to be used for "Standard" driving, technically it stands for "Sport".
Thanks for the picture clarification! Did you get this from the net or do you have your manuals at work?
Steve
Received 4,435 Likes
'71 Pinto
For 03 S was called Standard Mode – W/S. I don’t have my manual in front of me but if memory serves this is the way the brochure explained it. In 04 they renamed W (winter) to C (comfort).
Originally Posted by DWP
That didn't occur to me, since I never use C/W mode, but it sure makes sense that if the car doesn't start in first gear, it wouldn't downshift into first gear at low speeds, either. Presto, little or no engine braking at low speeds. I have to wonder, though, if the transmission is really disconnecting the engine from the wheels when you back off the pedal in C/W (which would be the only way to totally prevent engine braking) or if the transmission just keeps itself in a high enough gear to minimize engine braking. Remind me to drive up to Tahoe http://video.dot.ca.gov/asx/50-ski-run.asx
Slippery weather driving is full of these little tricks, but they are not all good for all situations. I have forgotten to switch the trani to C mode on some occasions and everything was fine. When I drive down long and steep downhill passes in icy conditions (it happens about 3 times a year) is the only time I will ride the brakes
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
Steve A.
W211 & Q7
Otto might actually be wrong after all!
SAguirre is right "the lower gear allows the engine to have more mechanical advantage to either move forward..." when car is MOVING -- but not idle on a hill. (becasue 1st gear gets you more power, you may feel "sport" driving but all the cars on the road have 1st gear --> all cars are sports cars ???)
don't try to prove my wife is wrong
Marriage Bible
Rule #1 -- Wife is right always
Rule #2 -- If wife is wrong, refer to Rule #1
#32
yes, I can be wrong but my wife can't. I am pretty sure that my car rolls back on a hills when both my feet are NOT on the pedals in "S" mode, I tried to prove it hundreds of times but it still rolls back. Unless MB implements SBC-HOLD in US models in the future; otherwise, my wife do NOT allow me to have another MB car.
SAguirre is right "the lower gear allows the engine to have more mechanical advantage to either move forward..." when car is MOVING -- but not idle on a hill. (becasue 1st gear gets you more power, you may feel "sport" but all the cars on the road have 1st gear --> all cars are sports cars ???)
Marriage Bible
Marriage Bible
Your marriage will last a long long time!!
You are correct about the cars rolling back in general. My E will still roll back on some hills while still in S mode if the hill is steep enough. However, if you have the car in "C" mode, the car will start in second gear. This means that if you are at a stop in "D" but also in "C" mode, the transmission is in second gear, not first. The minute you let go of the brake pedal, the car will still be in second gear. This is why I think that the engine at idle will not be able to hold the car in second as well as it can in first.
Steve
#33
2015 ML 350
Why does the Owners Manual reccomend AGAINST changing the setting from C to S unless the car is in Park? I know you wouldnt want to change the setting while the car is moving or doing its shifting thing, but I imagine if you shift from S to C at a traffic light while stopped, the tranny would simply move into 2nd & wait for the light to change & the driver to step on the gas.
#34
I have to admit I tested this on a loaner E320 4 Matic wagon before I did it on my car. Isn't that what loaners are for????
I think that MB wrote that to cover their A. I think that there cannot be any negative issues as long as you don't hit the button right when the transmission is actually shifting (even that might be OK, but I will not try it). I think that is totally impractical to change that setting while in Park.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Just my view here,
Steve
#35
W211 & Q7
#36
W211 & Q7
#38
I agree that in normal driving conditions S mode is better but did he specify if it was better during the break-in period?
(my apologies to the jurisprudential types out there)
#39
2003 E-500
you can change it anytime after your car is fully stopped; otherwise(change it while moving), it just likes you touch shift gear from 1st gear to 2nd gear or from 2nd gear to 1st gear. (all gear shifts are controlled by computer, not you -- this is why I don't think w211 is a "sports" car.)
When you are in the W mode, the car will not roll back no matter how steep the hill. It is locked through the transmision in some manner, I believe, but not due to it's being in 2nd versus 1st gear. When you put car in Reverse while in W mode, you also will start backing up in a higher Reverse gear, and this is also noted in my manual. In W, you will normally start in 2nd BUT can still force vehicle into 1st by holding the shift lever until 1 appears. I like W when in slow traffic on hills and it's also much better in the snow.
You can easily see the difference by having the car in D while on an up hill and switching between S and W. In S, car will roll back unless you hold the brake or apply some power. While in W, the car will not roll back and the brake is not needed. You must put car into Reverse to move back while in W.
#40
W211 & Q7
For the guys that roll back, are you in a 5 speed? I am in E500 7 speed and never had it roll back.. Just wondering.
#42
2019 Mercedes Benz S500L AMG Premium Plus
Is it possible the "hold" feature was designed for those areas where a manual transmission is more widely used/available?
#43
Steve
#44
W211 & Q7
I know this is a tough job for mb comand programmers who are still busy figuring out preset radio stations.
program logic A:
1. car is stopped (speed odometer is 0 mph)
2. tilt sensor is not leveled (tilt sensor is from alarm system)
3. automatically switch to "C/W" mode to prevent rolling back
4. switch mode back when speed odometer is > 0 mph
program logic B: (simplifed logic A becuase it is too tough)
1. speed odometer = 0 mph then switch to "C/W" mode
2. speed odometer > 0 mph then switch to user setting mode
still too tough?
option C
MBUSA provides SBC-HOLD as an option for US customers.
(May I spend money on SBC-HOLD?)
finally, there is a solution accepted by mb programmers and mbusa because they do not need to do anything
solution D
1. select "C/W" mode then forget your car has this switch.
solution E is even better
1. factor sets to C mode and decontents this switch from panel -- save cost in switch and sbc-hold. it definitely will save more in potential law sues of running over people behind car due to lacking of sbc-hold.
program logic A:
still too tough?
option C
solution D
#45
2003 E-500
I have a 2003 E-500 with the older five speed transmission and it has the anti-roll back feature when you select the W mode. I also had this same feature in a 1997 E-320 when I used the W mode. I don't believe that implementation of it in my 2003 version W-211 has anything to do with the SBC system which I also have, but think it was a carry over from their previous transmission implementation. A friend of mine has a 2003, E-320 and also has the anti-roll back feature when he selects the W mode.
Perhaps when MB went to the "C" instead of "W" for later models, they may have deleted the anti-roll back feature.
#46
W203 C240
On my '03 the two modes are labelled as "S" and "W", which stand for (as I recall) "Summer" and "Winter." I thought that the point of a second-gear start in "W" was to lessen the possibility of wheelspin when starting on ice or snow. Snow and ice being unknown here in the Big Tomato, I've never had the car in "W". Am I missing something?
Have driven the car hard in Comfort, Sport1 & 2, only noticed a very slight firmer ride in the sport mode...however nothing dramatically different. I may be wrong This is in an 03 e500 sport as well
#48
I have been reading this thread and I must agree with the German person that advised using the 'S' mode or Standard setting on the gearbox during the 'break in' or the English 'running in' period.
I understand what members say about the manual, BUT...... When running in the engine\gearbox, the purpose is to get the mechanical parts gelling together with the minimum of strain or stress. We are advised not to over rev the engine, stay at constant speed and on a manual gearbox not select to higher gear to early!
By engaging a high gear too early you are putting a great deal of stress onto the engine, it is trying to pull the weight of the car and the engine is not within its correct working range.
I am struggling to put my thoughts down onto paper, but if you put the vehicle in 'C' Comfort or 'W' on older models and floor the throttle from a standing start the gearbox should pull away in second, but imediately change down to first. Some seven speed vehicles might not do this because the car has learnt our driving habits, and has pulled away and got up to an acceptable speed that will cope with second gear.
Hopefully I have managed to explain what I mean?
Regards,
John
I totally agree with Steve's comments about the use of the 'C' setting when driving in adverse conditions and my observations are not meant to criticise his valuable contribution.
Regards,
John
#49
I have no idea (other than that I was simply wrong) why I thought it had rolled back in "C" mode. Just when the car seems to be rolling back, it feels as if the brakes are engaged. I say this because when I then move the shifter to P, there is no clunk. You know what I mean? It is as if you parked on a steep hill without the parking brake and then you take the car out of Par, you hear that noise from the transmission. Well, with this feature, it makes no sound or clunk as if it were the transmission that doe the stopping. I bet it might be the SBC.
I still think that if the car did not have this feature, it would roll back faster in "C" than it does in "S". That is quite simple logic. It also makes sense the Mercedes puts this feature on the "C" mode since it is more prone to roll back. Since I drive on in and around hills a lot, I will be using C mode more often now.
As per the parking on a hill in and not using the parking brake: My father was the big trainer in this. He always forced us all to first stop the car, put on the parking brake, then put the car in neutral and let the car rest on the parking brake, then we could put it in park. This way, when we took the car out of Park, it never made any strange noise. This might not be necessary, but my whole family does it. We always had driveways that are on a steep angle. Also, when towing a trailer out of the water on a boat ramp, it is much easier on the transmission not to use the parking pin to stop the car!
So just to set the record clear!!! I was wrong!!! NOT OTTO!
Steve
