E-Class (W211) 2003-2009
Strange Idle
Old Nov 21, 2024 | 07:09 AM
jntfmc's Avatar
W211
Strange Idle
Hi, I drive W211 2003 e320, I got problem when engine gets hot I am getting rough idle when transmission is in gear it is too feelable, if it is parking or neutral it is less noticeable but in both condition RPM is low, when in P/N it has 780RPM, when changing gear D/R it is going to 600RPM and comes idle and jerking. But everything is gone when battery lights comes on, Electrical Consumers Switched Off and everything is fine, RPM is in gear or not is going up to 900 and car runs perfect, no jerks, no idling.
Changed MAF sensor, working perfect
Changed Fuel Filter
Both Battery is good
Alternator is good
Can anyone say what does this need to be fixed? Thank you
Old Nov 21, 2024 | 08:52 AM
jntfmc's Avatar
W211
I had to check with codes multiple times, only have secondary air valve and catalistyc sensors. Nothing other, So that's why I am here
Old Nov 21, 2024 | 05:36 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
perfect!
you got it!
Secondary air valves leak in air into exhaust that oxygen sensors flags as lean combustion making engine too rich and wonky fuel map.
Reading your fuel trims should confirm.
Old Nov 22, 2024 | 03:19 AM
jntfmc's Avatar
W211
Yeah, but why everything is working when there is no power in interior?
When that warning light comes on dash, I can't use my comfort features like seat heat, seat moving and other. When this happens the engine is working perfect, no idling, no jerking, when I stop I can't even feel the engine is running or not
Old Nov 22, 2024 | 03:45 AM
You were dealing with two codes and now this... Are you saying your codes are related to an electrical issue?
Old Nov 23, 2024 | 03:33 PM
jntfmc's Avatar
W211
I think there is only electrical issue which is caused by undefined reason, I just want to know if someone had this problem to give me advice from where should I start to solve it. Those codes are not causing this problem, because when electrical consumers are turned off everything is fine and maybe problem in Relay? Why there is low RPM until comfort block is getting electricity and when it is turned off by computer, engine is working smoothly. IDK
