E-Class (W211) 2003-2009
Headlights
Old Dec 16, 2024 | 07:46 PM
Psaboic's Avatar
2012 ML350
Headlights
This has probably been beat to death, but after searching I've found too much conflicting info, so......here goes. I'm now working nights and am going to be driving 40 miles each way on dark rural roads. Needless to say the stock halogens on the 2004 E 320 I will be using are not going to cut it. I would either like to upgrade the low beams to HID and high beams to LED, or both to LED. HID won't work for high beam due to the lag time to full brightness.
That said, can anyone PLEASE recommend a H7 HID and/or LED set that won't flicker, turn on and off repeatedly or set a warning message. In other words plug and play with no issues. Many, MANY thanks folks!!
Old Dec 20, 2024 | 12:16 AM
Psaboic's Avatar
2012 ML350
Ok, 4 days with not a single answer I guess I need to look elsewhere for help. Thanks anyway.....
Old Dec 20, 2024 | 08:58 AM
mooseman's Avatar
This forum is pretty dead, (like most of these cars by now)
Anyways I'd say you have bigger problems than headlights if you are relying on a 20+ year old E class for regular commuting "driving 40 miles each way on dark rural roads". Probably one of the last cars I'd want for that type of use case. Get yourself a used Toyota.
Old Dec 20, 2024 | 09:31 AM
Psaboic's Avatar
2012 ML350
Well, since I am currently using a 42 year old W123 diesel with close to 400,000 miles for the same commute, the W211 will be a nice upgrade.....yes it is not a diesel but it will do the job.
Old Dec 20, 2024 | 01:34 PM
nguyenphananh's Avatar
slk280
For low beam, Im using the DDmtuning HID kits. Seems to be very reliable... but remember to buy the CAN BUS error canceling kit (to prevent flicker). w211 headlight designed to be closed off from behind, so not sure the after market LED kits will work. LED kits requires open space for heat ventilation... wont work reliably on w211 headlights
