battery issue comes after cold
When the temperature is normal, a message will appear that the “Convenience Functions Temporarily Unavailable " is temporarily disabled whenever started, and it will disappear after a few minutes of driving.
However, today, the temperature drops to 0 or even below. About 1 minute after starting in the morning, a red alarm "battery visit workshop" will appear on the screen, and the "convenience function" cannot be used as well。
My solution was to turn it on for a few minutes, then turn off the engine and restart it, so that the "convenience function" would soon disappear and I could use the seat heating function.
After reading a lot of discussions about this in the forum, I called the UB parameter, when the key is at 1, it is about 12v, and it is maintained at 13.8-14.1/14.2 after starting. The strange thing is that when my foot on the gas, the voltage will drop to around 13.6, 13.4, while foot off it, and the voltage will go back to 14.1-14.2, which makes me wonder, I changed the small battery in the engine compartment last year, do I also have to change the main battery and voltage alternator?
thanks~
thanks~
Nothing wrong with your alternator, voltage above 13V indicate it's both powering the car AND charging the main battery.
It may well be the fuse to the AUX was blown when it was bad and thus has never been charged since installed.
Let's check this quickly!
- start the engine
- use your voltmeter on DC settings
- check both of your battery voltage...
We expect main to be fine. Let's see that AUX is above 13v and not below 12v.
The main battery I use is rated at 900 CCA but will test a bit over 1000 CCA or so when new. The Yuasa auxiliary battery I use is rated at 200 CCA but can test around 250 CCA when new. The CCA will drop over time as the battery ages. FWIW, I replace my main battery when the CCA drops below 600 CCA during testing; this is about a 3-year maintenance item for me. Beats being stuck at a roadside rest area midway between San Antonio and El Paso Texas with a dead battery and the nearest available is 120 miles away.
The electrical modules on a W211 are a power hog; yesterday while performing maintenance on my car I noted the amperage draw with the key in position 2 (engine not running) is approximately 15 amps. When the voltage drops to around 12 volts the communication system begins failing. The convenience features are disengaged to conserve power on a failing main bus.
Auxiliary battery is only used as a backup and is switched into the system when the main bus voltage drops below a pre-determined point. Main intent for use is to provide emergency power for the SBC brake system. When the car is started, the K57/2 relay connects the auxiliary battery to the charging system for approximately 15 minutes then disconnects. If main bus voltage drops, the relay reengages.
See attached for info on the system.
- start the engine
- start the engine
11v when cold stated, yep, both cold and old hahaha
It fails when AUX is forced to use higher current.
AUX puts out power anytime MAIN voltage is below AUX voltage.... 11V cranks included.
