E350 died when driving; cranks but no start
I have a 2006 Mercedes E350 with 140k miles, and it has served me well until yesterday. While driving home, I hit the curb hard with the passenger-side tire. About 5 minutes later, the car broke down and wouldn’t start.
- When I turn the key, the engine cranks and the car trembles, but it doesn’t start.
- After multiple attempts, it occasionally starts for about 5 seconds and then dies again.
- The tow truck driver suggested it might be a fuel pump issue.
- Could it be the fuel pump, fuel pump relay, or something else?
- What’s the best way to confirm if the fuel pump is the issue?
- If it’s the fuel pump, which specific part (module, relay, or pump itself) should I check first?
If there are no codes associated with fuel pump, and nothing else is obvious. You can test/diagnose the fuel pumps by checking the beginning of this video. It applies to the W211 as well. You can also rent a fuel pressure gauge, and there should be a Schrader valve on the engine fuel rail.
If you conclude your fuel pump is faulty, check FCP Euro
1 - Trial and error: throw parts at it.
2 - Get an MB aware scanner, read the error codes and follow the crumbs
3 - Find the electrical specifications of the part of interest, and with the appropriate instruments confirm the part is up to specifications.
4 - Let someone else figure it out.
CPS is a common issue for this car.
For a summary of crankshaft position sensor failure and replacement
https://www.mercedesmedic.com/crank-...sition-sensor/
Thanks guys. My situation is kinda bizarre. Its more difficult to get one scan than buying parts online. I just replaced brand new Fuel Pump Relay and CPS. No use and even worse. I tried to start the engine too many times while pressing the brakes. Now it only tires to crank for half second and then stops. I believe the battery still has enough power. I want to give it last trial before dumping it. Any suggestion what shall I try? I can replace the fuel pump assembly, only cost $350 parts fee. But not sure if it's worth.
