2009 Wagon Dies
What happened is you used ALT to recharge your flat batteries.
So over 100A had plenty of time to fry up something along the way to charging battery: ALT, SAM or BCM...
Do you have an AUX batt in the dashboard side??
> NORMAL PROCEDURE:
To prevent this NEVER JUMP A FLAT/dead battery.
Use a battery charger overnight on low batteries
A recent battery run flat is as good as dead.
ALT only regulates voltage. It can not regulate current : 250Amp Max
ALT puts out as much current necessary to deliver 14Volts.
Flat Battery will get overheated by 1,500.Watts of power... ouch!
