Suspension noise... NEED HELP
i've had a lower ball joint fail on the fwy (on my truck) and it's scary! leading up to the failure, i had a hard time returning the steering wheel to center but had no noise however that was a different car altogether.
in the end, keep us up to date with your findings during replacement!
See l https://mbworld.org/forums/e-class-w211/851113-w211-swaybar-mount-glue-lube.html
See l https://mbworld.org/forums/e-class-w...glue-lube.html
I suspect it had just softened enough to allow some movement between the nylon/hard plastic shell and the metal bracket + chassis.
If you get a bit of dirt between plastic & metal it start to grab & shudder when moved against each other under pressure - that is what I think causes a lot of strange but load noises in the suspension. Pops, bangs, squeaks that sound very serious, partly due to being directly against the metal of the chassis.
I used RTV between the nylon shell and the chassis + brackets. This (in my opinion) takes up some of the slack, prevents the nylon from moving around and/or provides some lube if it has to move.
Very cheap & easy fix, from what I can see won't damage anything, and rules the mounts out as a source of noise.
Keep us informed with what you find.
More Disappointment!. The more I read these posts, the more I convinced the culprit was the sway bar bushings. So I bought the Permatex Black like CS-W211 stated. I started the project today, and to mine dismayed, the sway bar's connections were totally different from online pictures and youtube links!. In order to remove the sway bar's brackets, I will need to lower the subframe!. On the passenger side, the bolts can be access from above, despise they are very close to the frame and the alternator. The driver side, I couldnt see the bolt due to the power steering blockage. Lying on my back, and lacking of tools... It is very difficult to lower the subframe. So I will postpone, again, this project for the later day.
It is definitely the sway bar bushing!!. Last time trying to work on the sway bar, I wasnt able to do much due to the sub frame need to be lowered. However, I noticed the sway bar's bracket bolts, especially the driver side lower's, were slightly lose. Originally I losen it, trying to retighen with locktide. I noticed inside the bracket, the white "plastic" was totally crumbled, disintergrated. For some reasons I wasnt able to completely remove the bolt... so I retighten it to torque spec. Now the noises were significantly reduced, no longer happened every time like before. Next time I will order a new sway bar and have the shop replace for me.
