E-Class (W211) 2003-2009
Cmmand Cuts Out
Old Dec 8, 2004 | 10:49 PM
kort677's Avatar
'05 e320 cdi, '05 lexus rx330
Angry Cmmand Cuts Out
My command system has completly cut out, no sound no power, no nothing, it is going in for service on Friday, any comments?
Old Dec 8, 2004 | 11:54 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
Fuse????
Old Dec 9, 2004 | 02:43 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
..any comments?
No comment at this time..
Sorry had to..
Old Dec 9, 2004 | 04:18 AM
mbfan67's Avatar
pinto
i had the same thing happen to me a couple of months ago and the dealer found that the navi drive in the trunk died out. they told me that the whole system works in a circle if one thing dies the system will die. they replace the navi drive and all is going good so far, but before you take it in try resetting the command unit. i think the fuse is in the back trunk. good luck
Old Dec 9, 2004 | 04:55 AM
ninefourthree's Avatar
i ride a bicycle
pull fuse (i believe it's no. 6, 40amps) for "audio gateway"
it is identified on the fuse chart.
leave the fuse out for about 5 minutes. and stick it back in.
if it works, then you just need the software update performed on
your audio gateway control module.
