W211 E320 Bluetec AC Temp B/12/2 question.
New here. Quick question for you AC guys. I just got this car this week. AC not blowing cold and everything checks out, not throwing any AC codes. Fuses are fine. BUT…I’m not getting any power to the compressor and the B/12/2 pressure/temp sensor is showing 7 BAR on pressure and -150F on the temp side…Any idea why I would be getting -150F on the temp side? Could this be a “short to ground?” I’m certain -150F is not within the correct specifications. It is one 3 wire sensor, and I am getting pressure. Getting 70% signal to compressor, but no power to the compressor at all (supposed to be 700 Ma or so.) I am assuming that this sensor (or something else) is not allowing the compressor to engage. It’s a clutchless one. No error lights on AC and no CAN errors in any module. I’m stumped…Thanks so much for any help you guys may be able to provide…I’m looking forward to participating on this forum as I was on the other one for years helping folks with their 300D’s…
I was on this last year, and also thought the issue was the temp reading.
Also learned the hard way that if you have power switched on and pull the connector from the sensor, it will lock the A/C and you'll need a Star to unlock it.
I have exactly the same problem, my diagnostic tool is also showing an interieur temperature of -127 degrees. The temp sensor (n70b1) as i found on the internet is in the roof module. I manage to take it out and measured the ntc thermistor with 7,9K ohm on normal room temperature, when i was heating it with a heatgun it is dropping to 3,5K ohm. So it looks like it is working, but did you solve your problem already? friendly regards Adidas1977
Caution, if you go and pull the connector from the B12/2 and ignition is on the run position, AC will lock, and you'll need a Star to unlock it.
I remembered today, that I bought a new sensor last summer. Of course I had to try it as soon as I got it, but still no temp reading. Earlier I said that if you pull the plug when ignition is on the run position, it will lock the A/C. Well, not quite. When I got that new sensor, I just plugged it in to see would there be an actual temperature. And on that very moment I introduced no pressure situation, which locked the A/C.
I've tried to find the site where it was stated that only 4-zone A/C uses temperature, and that sensor would have four pins, but no luck so far.
I use iCarsoft MB V2.0, and it shows the sensor as B12/2, which seems to be misleading.
Be sure to depressurize that AC system before working the AC compressor conrtol valve loose from its tight o-rings fit. Because if you don't, it will shoot outta there like a 20mm cannon shell, ricochet off your concrete floor and embed itself in the wall on the other side of your garage. And when you buy the compressor control valve, be sure it has the dot on it and the little diode symbol on the end of it, indicating it's got the diode in it. A new control valve just might clear up your AC issues.
The problem was a ZGW DRACO coding error. After a low-voltage incident, the air conditioning DRACO parameters (and a few others) were showing NOT FITTED when they should have been FITTED. Seems the low voltage incident caused the ZGW to revert back to its factory level configuration. Tough one to diagnose, but I finally got it after testing everything from top to bottom. I went through each and every module, checking and comparing all the variant coding, that’s how I located the error.
