E-Class (W211) 2003-2009
08 E350 crank no start
Old Aug 27, 2025 | 10:01 AM
Arab's Avatar
08 E350
I have an 08 E350 I am not getting any fuel at the rails. I have tried to replace the relay and fuse with no luck. I can barely hear the pump cutting on when turning the key to position 2. If I tap the top of the housing plate on passenger side while trying to crank the car I start to get a little fuel at the rails so assuming my pump has gone bad. I searched for a fuel pump assembly to buy but can not find one that replaces both passenger and driver side pumps. Can anyone help me with this?
Old Aug 27, 2025 | 01:13 PM
MacVidMB-V8's Avatar
W209, W124
Before buying up parts you may not need, maybe do some more research?
Check for voltage at the pump(s).
And I know we sound like a broken record, but put a scanner on it, make sure there isn’t something else not turning on pumps.
Old Aug 28, 2025 | 03:11 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Fuel pump on passenger side. Fuel filter/regulator on driver's side. FCP Euro or Pelican Parts (who have great DIYs on their website).
Old Aug 28, 2025 | 03:48 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CONNECTOR EYE INSPECTION
the fuel pump is known to burn up its harness power connections - Visually inspect connector for oxidation at the tank top.
Good pump and clean filter help prevent higher currents.
