E-Class (W211) 2003-2009
Looking for Guide on how to replace the EL(electro ) Light on W211 Instrument Cluster
Old Sep 25, 2025 | 10:01 AM
laikos77's Avatar
W211 E280
Hi,
My W211 E280 2006 Facelift have issue on the clock side of the instrument cluster. The EL light is not working (I have tried crank the brightness to max). However the speedometer and RPM meter side is working fine.
I have bought the EL light but cannot find any guide on how to replace it. There are plenty video on repairing the instrument cluster however none of it provide the guide on replacing the EL light.
Replacement
Replacement
Replacement
Replacement
Clock EL light is not working
Old Sep 25, 2025 | 02:07 PM
TimC300's Avatar
Its pretty straight forward. Are you asking how it connects?
This thread has some photos that may be useful: https://mbworld.org/forums/cls-coupe...hting-fix.html
Old Sep 25, 2025 | 07:43 PM
laikos77's Avatar
W211 E280
To be exact, I cannot find a guide how to remove the old EL and reconnect the new one. The above guide does not really address that
Old Sep 27, 2025 | 01:20 AM
laikos77's Avatar
W211 E280
Hi,
I finally able to replace my Instrument Cluster backlight. This guide provide steps to fully disassemble the W211 instrument cluster:
This is the part I bought: https://www.aliexpress.com/item/1005...5ec21802pVLYlT
Replacing the Electro Luminesence require full instrument cluster disassemble.
Final result
Final result
Clock face, backlight was not working
after replacement
after replacement
Full disassemble
Full disassemble
Instrument Cluster connector. I did not remove battery
Old instrument cluster faace
Instrument cluster compartment. Need torx 25
